TR2/3/3A Driving lights / badge bar attachment.
Dick Burk
I want to install a badge bar to the front bumper overriders on a restored '59 TR3A. Available badge bars attach with a bolt and nut to a brace piece welded into the upper part of the overriders, however, my overriders do not have such a brace. I've been told there are badge bars that attach to the bolts that hold on the overriders. Is anyone aware of such badge bars, or an alternative solution? I've been unable to find anything online.
Thanks in advance.
TR3driver
Great Pumpkin - R.I.P
Why do you have the wrong overriders? All TR3A should have the braces, but it sounds like you have the TR2-3 version (which did not). The contour of the bumper bar is different as well.
Check with TRF. It appears that their RFN305 is suitable for use with the early overriders, but I couldn't find a photo or detailed description of it. It's just listed as the replacement for the factory 552399 bar.
https://books.google.com/books?id=Z...UQ6AEIKDAD#v=onepage&q=triumph 552399&f=false
rnpennington
The best place for badge bars I have found was Rimmers in the UK.. I was able to find one for my TR4 and those are seemingly made of unobtanium. I'll bet you find what you want there.
M_Pied_Lourd
I made a couple of simple mounts for my driving lights that could also be used for mounting badges. Some video here....
https://youtu.be/Y7q_UlS2d7o
Cheers
Tush
MadRiver Bracket for mounting driving lights to badge bar? Triumph 7
R TR4/4A TR4A badge bar for driving/fog lights? Triumph 3
C How to install Stone Guards on driving lights? Austin Healey 7
C Wiring for two front Driving Lights? Austin Healey 22
maxwedge5281 Driving Lights [picture posting opportunity!] Austin Healey 25
Patrick67BJ8 Lucas SLR Driving Lights installation Austin Healey 26
M Headlights and fog driving lights Triumph 44
bighealeysource Driving lights electrical question Austin Healey 3
T PIAA driving lights arrived today - now what Triumph 12
bighealeysource Hooking up driving lights Austin Healey 2
L Spitfire Driving lights for the spit... Triumph 5
S Driving Lights Austin Healey 3
angelfj1 Period Correct Switch for Driving Lights Austin Healey 2
angelfj1 T-Series Period Correct Switch for Driving Lights MG 6
angelfj1 Period Correct Switch for Driving Lights Other British Cars 3
O Lucas Driving Lights - ID help MG 13
R MGB Driving lights on rubber bumpered mgb MG 17
RobSelina cheap driving lights Spridgets 0
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
K TR2/3/3A Mystery clunking and banging from rear of car when driving over rough road or bumps? Triumph 14
K TR2/3/3A Thermostat for hot summer driving? Triumph 1
S Spridget Mountain Driving Tour : Mid-Atlantic Spridgets 8
6 Seeking 1967 MGB roadster in good driving condition MG Classifieds 3
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
T how to have music/radio when driving Spridgets 33
H driving dog [gear] for distributor? Austin Healey 17
J Anybody driving a 2018 Jaguar XJ? Jaguar 3
jdubois GT6 Driving the mainshaft bearing into the gearbox case. Triumph 5
T 100/6 vs 3000 driving experiences Austin Healey 71
Jim_Gruber Thoughts on driving Bugsy with the hardtop installed. Spridgets 32
R Winter Driving Austin Healey 24
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
Airwave BJ8 overdrive stops working after a while driving Austin Healey 17
M Driving/Owning Comparison between TR3 and AH3000 Austin Healey 13
M TR2/3/3A Driving Comparison between TR3 and AH3000 Triumph 40
vette Driving and/or Fog Lamp Bulbs Austin Healey 5
steveg Lousy driving light bulbs Austin Healey 0
bugedd Driving to elevation Spridgets 3
Got_All_4 TR2/3/3A Looking for advice in driving a TR3 with overdrive Triumph 6
steveg Healey hot weather driving observations Austin Healey 2
B Distributor driving gear orientation Austin Healey 2
turtle Avengers Assemble! Tony’s Driving a Healey... Austin Healey 1
2 TR2/3/3A Winter driving question Triumph 10
JPSmit Driving on the 401 today Other Cars 5
T TR2/3/3A 1/4 mile fast time driving technique Triumph 15
5 T-Series TF 5 speed conversion AND upgrade 4.55 Rear -- any driving problems? MG 6
bugedd How is your driving weather? Spridgets 12
KVH TR4/4A I Sure Like Driving My Triumph Triumph 8
K Spitfire '78 cuts out after many miles of driving Triumph 8
