TR2/3/3A Driving Comparison between TR3 and AH3000
mastaphixa
Bronze
For those of you who have owned both, give me a comparative owning/maintaining/driving experience between a TR3 and an AH3000. I am familiar with and enjoy the TR3 but have always been infatuated with big Healeys. Knowing what they say about meeting your hero's, I would be interested to get a read on the two cars. Retirement is knocking at the door and I need to make a decision.
Thank you.
Steve in Newnan, GA
glemon
I haven't had either, but my brother had a TR3 for about 25 years or so, I drove it quite a bit and toured in it as well. I had a 100 for ten years. The Healey was a little more refined with a more closed up cockpit, better steering and ride. Engine with my 100 was pretty much a wash. I am sure a six would pull a little better.
Note this is all relative, coming from a Miata or even an MGB you would probably say the opposite about the Healey, they are still rip roaring sports cars. Wider cockpit too.
Geo Hahn
Drive up in a Big Healey and you feel like you've 'arrived'.
Drive up in a TR3 and you feel like you've 'cheated Death again'.
DougME
+1 to that. I've driven TR-3's and the steering on both of my "almost" daily drivers has always been a job. The few Healeys I've had a chance to drive have been even more of a job. I usually describe it as like driving a truck, I've heard others say the same.
M_Pied_Lourd
I just read and article recently, I will see if I can dig it up at home, but it was a comparison between the MGA/TR3A and Healey. If I recall correctly, based overall engine/performance/handling/ride/comfort etc the MGA was first, TR3A second and the Healey was 3rd.
Will see if I can find it.
Cheers
Tush
M
mastaphixa
Bronze
Well as far comparing the steering goes, the TR3 I have been lucky enough to work on and drive has the rack unit mod done to it so it is VERY precise. Maybe even more so than my Miatas. I've heard the original steering on the TR3 left something to be desired.
Geo Hahn
...based overall engine/performance/handling/ride/comfort etc the MGA was first...
I suppose if one gives 'ride & comfort' equal weight as 'engine & performance' then the TR3 may come up short in many comparisons.
The TR3 handling is just what it should be (IMO). But then the assessment may depend on whether you weight 'parallel parking' equally with 'twisty roads'.
TRMark
Bronze
I could see putting a cruise control in an AH3000, not so much a TR3.
poolboy
If you're talking a Mark lll and a TR3..that's almost like apples and oranges.
CJD
Everyone knows Triumphs are forged in the fires of Hades, while Healys are for girly men.
Geo Hahn
Well, here's one difference. On a recent (unpaved) desert/mountain drive we discovered that the Healey has less ground clearance than the TR:
bnw
I've never roasted in a car as much as I did in a 100 6. As for me, you can't beat the cut down doors of a TR3.
2long
Ill say the 3000 is prettier, fussier, poor ground clearance and more expensive to buy/fix/maintain/repair. The TR is rorty, more counter-culture, more exposed to the elements, pure british, and a rugged bulldog. My 2 cents!
Dan
glemon
Several years ago my brother and I took off from our homes in Nebraska to see the vintage races at Elkhart Lake, Wisconsin. I was in my 100, my brother and his freind in a TR3. It started off on a hot summer day, by the time we got up to Wisconsin it was dark and cooling off. When we stopped I mentioned I was finally getting comfortable in the Healey, they said they were getting cold in the TR3, and considered putting the top up.
doc50
I've had 5 TR3s, and a couple Healeys. One doesn't so much drive a TR3 as aim it!
Thom
1959 TR3
#TS34909L(O)
M Driving/Owning Comparison between TR3 and AH3000 Austin Healey 13
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
K TR2/3/3A Mystery clunking and banging from rear of car when driving over rough road or bumps? Triumph 14
K TR2/3/3A Thermostat for hot summer driving? Triumph 1
S Spridget Mountain Driving Tour : Mid-Atlantic Spridgets 8
6 Seeking 1967 MGB roadster in good driving condition MG Classifieds 3
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
T how to have music/radio when driving Spridgets 33
C How to install Stone Guards on driving lights? Austin Healey 7
C Wiring for two front Driving Lights? Austin Healey 22
maxwedge5281 Driving Lights [picture posting opportunity!] Austin Healey 25
H driving dog [gear] for distributor? Austin Healey 17
J Anybody driving a 2018 Jaguar XJ? Jaguar 3
jdubois GT6 Driving the mainshaft bearing into the gearbox case. Triumph 5
T 100/6 vs 3000 driving experiences Austin Healey 71
Jim_Gruber Thoughts on driving Bugsy with the hardtop installed. Spridgets 32
R Winter Driving Austin Healey 24
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
Airwave BJ8 overdrive stops working after a while driving Austin Healey 17
vette Driving and/or Fog Lamp Bulbs Austin Healey 5
D TR2/3/3A Driving lights / badge bar attachment. Triumph 4
Patrick67BJ8 Lucas SLR Driving Lights installation Austin Healey 26
steveg Lousy driving light bulbs Austin Healey 0
bugedd Driving to elevation Spridgets 3
Got_All_4 TR2/3/3A Looking for advice in driving a TR3 with overdrive Triumph 6
steveg Healey hot weather driving observations Austin Healey 2
B Distributor driving gear orientation Austin Healey 2
turtle Avengers Assemble! Tony’s Driving a Healey... Austin Healey 1
2 TR2/3/3A Winter driving question Triumph 10
JPSmit Driving on the 401 today Other Cars 5
T TR2/3/3A 1/4 mile fast time driving technique Triumph 15
5 T-Series TF 5 speed conversion AND upgrade 4.55 Rear -- any driving problems? MG 6
bugedd How is your driving weather? Spridgets 12
KVH TR4/4A I Sure Like Driving My Triumph Triumph 8
K Spitfire '78 cuts out after many miles of driving Triumph 8
D Ticking noise when driving Austin Healey 8
anarchy99 Driving season... Spridgets 2
Sherlock It's driving season finally! Spotted 5
Jer 2014 Driving Season... Spridgets 8
S Driving Lamps - how to tighten? Austin Healey 8
AHS TR2/3/3A Resto [almost] finished - first driving impressions Triumph 16
toysrrus TR2/3/3A Lucas "Driving / Fog" Lens wanted: Triumph 9
K TR2/3/3A A cut down side curtain for Fall driving? Triumph 7
RickB Installing flip front kit, what's easiest way to secure back of bonnet for driving? Spridgets 40
S Highway Driving Spridgets 22
vette Driving/Fog Lamps Austin Healey 3
S Summer Driving Spridgets 13
M TR4/4A @ The driving stage with ALOT of minor " fininshes" Triumph 5
T TR6 Brake caliper lock after some driving Triumph 3
