Everything's working right! Wow!
sparkydave
I do believe I achieved a rare occasion this weekend; everything is actually working properly on the Midget for once. Usually there's been some nitpicky thing that wasn't quite right (names like Zenith and Lucas come to mind), but after I tightened up the handbrake and tightened the leaking shock plug, I realized I don't think anything else needs fixing right now. Even the flaky seat cushion switch decided to work so the seatbelt buzzer wasn't blaring at me to fasten my already fastened seatbelt.
Here's hoping I didn't just curse myself. I guess I'll find out at the car show next Monday! /bcforum/images/%%GRAEMLIN_URL%%/driving.gif
jlaird
Way to go, make us set up and notice.
Morris
Way to go, Dave! I wonder if that day will ever come for me.
Platinum
I'm just glad to know you ain't under water, Dave!!
H Don't you love it when everything is working right Austin Healey 1
bgbassplyr "Everything was working when I parked it." Triumph 7
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
R TR6 Mazda Miata ride, everything else TR6 Triumph 13
steveg Steve Kingsbury has lost everything. Austin Healey 11
Boink Center justification on everything now... FORUM Navigation Questions 3
B Everything runs better with this mod - all models!!! Spridgets 7
PeterK General TR Holden UK sale 15% off everything Triumph 0
Randy Harris Timing is everything - the question is - is this the time? Austin Healey 14
7 Its driving season and everything works Triumph 5
Frankenhealey Aluminium everything - weight saving? Austin Healey 3
S I've tried just about everything but....... Triumph 7
Tabcon EVERYTHING MUST GO!!! Racing 3
T Getting everything out of the M/C Spridgets 10
C Everything was goin good... now no brake lights Spridgets 8
jlaird Everything loaded up Spridgets 13
regularman Do you paint everything? Spridgets 2
G When you rebuild your car double check everything Triumph 7
bcliff New Owner, need info, parts, and everything! British Motor Corp 5
jlaird Everything you never wanted to know about bolts Spridgets 0
D Trying to get back working on the 1974 Midget Spridgets 11
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A my OD stopped working after it was working Triumph 25
D TR2/3/3A Traffic at or and horn button not working Triumph 2
tr6nitjulius For Sale TR6 working/clean parts 4sale Triumph Classifieds 0
O Spitfire Tail lights not working Triumph 6
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
rgfrey 1959 Low Beam Headlights Not Working Austin Healey 5
Celtic 77 MGB Non working tach. MG 4
M Tachometer not working following ignition upgrade Austin Healey 10
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
KVH General Tech Speedometer Not Working Triumph 5
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
S TR2/3/3A Speed O not working Triumph 27
M Wiper Motor Problem Not Working Spridgets 5
TRclassic3 TR4/4A A type OD working in 3rd but not in 4th Triumph 5
W Healey 100 Overdrive stopped working Austin Healey 15
1 MGB Lights not working MG 11
A MGA High beam indicator light not working MG 2
1 MGB Speedometer and tachometer on '66 MGB are not working MG 8
2billydavies TR2/3/3A generator doesn't appear to be working Triumph 7
Airwave BJ8 overdrive stops working after a while driving Austin Healey 17
warwick-steve Direction indicators not working Austin Healey 29
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
Martinld123 Austin Healey 100 BN2 fuel gauge not working Austin Healey 13
Jim_Gruber Brake Light - Getting them working Spridgets 8
Superwrench Tach not working Austin Healey 6
M TR2/3/3A Panel lights not working........ Triumph 5
Rhodyspit75 Working on the Bugeye body Spridgets 19
