Tach not working
Superwrench
Anybody have trouble with tach after putting in electronic ignition ? Been helping friend with his BJ8. Put new wood dash panels in. After installation, tach won't work and it did before removal. Talked to Nisonger and he asked if he has electronic ignition in it ? He said that could cause it ? The electronic ignition has been in this car for 4 years. I have checked wiring and grounds and it should work. Any help will be appreciated ! Thanks !
Keoke
If possible switch dizzy to another car and see if it works it could have failed for some obscure reason????
Be sure the pick up loop is correct.
If it works in the other car check your installation again.
OR: you may have to update the Tach.
vette
Seems to me that the electronic ignition has nothing to do with it, since the ignition and the tach have been working in the car together for 4 or more years. You know the old rule, if it worked before you changed things, and it doesn't work after you changed things, then it's something you did. Did you change polarity on the whole car which necessitates changing the connections on the back of the tach? Did you connect the tach exactly as it was before? Did you possibly short out the tach and cause internal damage. This is unlikely but possible.
steveg
In the thread and pdf referenced above the little wire loop thing on the back of the tach is mentioned as being able to be looped incorrectly, causing tach problems. Also a resistor on the back inside which goes bad.
Keoke
Yep absolutely right
Patrick67BJ8
my tach had problems, low reading, after my ground up restoration but none before with Pertronix. I was told to do a double loop on the backside connection, but I ended up sending it to Nisonger at about $300. They said it will now work with all electronic ignition systems. Be sure to check all Dizzy connections especially if you converted it to Neg ground. I even added another ground strap near the engine motor mount and frame on the Dizzy side.
Celtic 77 MGB Non working tach. MG 4
Mowgli81 RPM / TACH not working. Austin Healey 4
Jim_Gruber Tach decided to quit working Spridgets 4
T My tach stopped working Triumph 9
M Tach stopped working. Any opinions? Spridgets 6
J Tach not working Triumph 6
Z 68 sprite door panels [and working tach now] Spridgets 3
PATR8 Tach not working [MSD Ignition system] Triumph 1
S Tach not working correct Austin Healey 5
B MGA Tach drive issue MG 1
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
jackq Wanted Need a C Tach MG Classifieds 2
S Sticky Tach Spridgets 2
Joe Reed MGB Tach slow to wake up...why? MG 6
Lin Tach drive housing for BT7 Austin Healey 4
HealeyRick Tach Trouble Spridgets 2
W Tach wiring problems Jaguar 12
Marvin Gruber BJ7 tach cable location. Austin Healey 3
EWD TR6 ‘74 Tach Triumph 7
PAUL161 T-Series Lazy Tach MG 3
boxofparts MGB busy tach on 1979 MGB at 75 mph MG 3
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
J 1965 BJ8 Tach Austin Healey 3
longbridgehealey Alternator conversion and tach Austin Healey 9
Healey Nut Mechanical tach drive Austin Healey 2
Healey Nut Mechanical tach drive assembly Austin Healey 4
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
S TR2/3/3A tach cable lubricant Triumph 4
D BT7 tach question Austin Healey 8
5 Tach Drive Generator for a Bugeye Spridgets 2
I Tach help Spridgets 3
Marvin Gruber BJ8 tach Austin Healey 9
JimTR4 TR4/4A Capping off redundant tach cable connection Triumph 0
Zitch TR4/4A Tach and Speed inner gaskets Triumph 13
W Use of original Tach Spridgets 8
A Need help wiring my tach Spridgets 11
Patrick67BJ8 Tach Hookup Instructions from Nisonger Austin Healey 23
S TR5/TR250 tach problems Triumph 2
J Hunting tach and back fire TVR 8
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
M Tach generator gearbox Spridgets 6
M Strange Healey Tach Austin Healey 9
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
busybrit Tach stops when flashers are turned on !! Jaguar 3
busybrit Electrical tach issue on Aston Martin DB5 Other British Cars 2
AngliaGT What Goes to the Left of the Tach? Spridgets 3
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
J How can I tell if I have a negative ground tach? Austin Healey 5
E TR4/4A Speedo v Tach cable Triumph 2
rjc157 tach goes crazy Austin Healey 8
