Okay, I received my rebuilt Tach with the instructions I've attached. I have a Pertronix Ignition, Negative Grd car. I'm not sure how to hookup the Tach after reading their instructions.
First Paragraph: Don't connect any of the wires that are part of the original loop.
Third Paragraph: Not sure what they really mean for me to do. The rebuilt Tach only has one white wire coming out of the back of it. The 1st paragraph says not to use any of the "loop" wires. Do they mean to cap the original Loop wire? If yes, then should I run a wire from the Neg terminal of the coil to the white wire that is coming out of the back of the Tach?
There's a total of 3 wires that are hooked up too the Tach, Black for grd, White from ignition for power and the White wire coming from the Neg terminal from the coil.
I spent almost $300 having the Tach rebuilt so I can't have any mistakes in hooking it up.
Thanks guys!
Thanks guys!
