Lazy Tach
BJ8TONY
Any simple suggestions for repairing a lazy tach other than having it rebuilt.
I am just completing restoration and tach/car has not been used for 6+ years.
It did work fine when last driven.
Thanks
RAC68
Hi Tony,
The Tachometer in the BJ8 is electric and senses the pulse through a looped ignition of wire. Depending upon the condition of the connections of the white wire running from the ignition switch to the ignition coil and the way the coil is set into the back of the tach, pulses may not be sensed properly. Tach response can also be affected by the addition of electric ignition components and the way required changes were performed if polarity was converted to negative.
Also, depending upon the storage of the tach during restoration, I have seen where spiders have penetrated the mechanism with webbing that has resulted in an encumbrance to proper performance. Take a look at the BJ8 Tach documentation available in the Technical section of the Healey6 web site https://www.healey6.com/technical.htm under ā€œGaugesā€ for some additional information and ideas.
Good luck,
Ray (64BJ8P1)
PAUL161 T-Series Lazy Tach MG 3
5 Lazy Tachometer Spridgets 14
glemon General TR Adjustable Trailing Arm Brackets, Cheap and Lazy, or clever like a fox? Triumph 0
milemarker60 Front Suspension Bolts/Nuts - Tub Dolly - LAZY!!! Triumph 2
MattP Cheap and Lazy windshield Restoration & Tools 2
B MGA Tach drive issue MG 1
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
Celtic 77 MGB Non working tach. MG 4
jackq Wanted Need a C Tach MG Classifieds 2
S Sticky Tach Spridgets 2
Joe Reed MGB Tach slow to wake up...why? MG 6
Lin Tach drive housing for BT7 Austin Healey 4
HealeyRick Tach Trouble Spridgets 2
W Tach wiring problems Jaguar 12
Marvin Gruber BJ7 tach cable location. Austin Healey 3
EWD TR6 ā€˜74 Tach Triumph 7
boxofparts MGB busy tach on 1979 MGB at 75 mph MG 3
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
J 1965 BJ8 Tach Austin Healey 3
longbridgehealey Alternator conversion and tach Austin Healey 9
Healey Nut Mechanical tach drive Austin Healey 2
Healey Nut Mechanical tach drive assembly Austin Healey 4
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
S TR2/3/3A tach cable lubricant Triumph 4
D BT7 tach question Austin Healey 8
5 Tach Drive Generator for a Bugeye Spridgets 2
I Tach help Spridgets 3
Marvin Gruber BJ8 tach Austin Healey 9
Superwrench Tach not working Austin Healey 6
JimTR4 TR4/4A Capping off redundant tach cable connection Triumph 0
Zitch TR4/4A Tach and Speed inner gaskets Triumph 13
W Use of original Tach Spridgets 8
A Need help wiring my tach Spridgets 11
Patrick67BJ8 Tach Hookup Instructions from Nisonger Austin Healey 23
S TR5/TR250 tach problems Triumph 2
J Hunting tach and back fire TVR 8
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
M Tach generator gearbox Spridgets 6
M Strange Healey Tach Austin Healey 9
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
busybrit Tach stops when flashers are turned on !! Jaguar 3
busybrit Electrical tach issue on Aston Martin DB5 Other British Cars 2
AngliaGT What Goes to the Left of the Tach? Spridgets 3
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
J How can I tell if I have a negative ground tach? Austin Healey 5
E TR4/4A Speedo v Tach cable Triumph 2
rjc157 tach goes crazy Austin Healey 8
Sopwith_Camel tach-less Spridgets 11
J Tach drive housing eccentric Austin Healey 14
G MGB Tach and speedo rebuild. MG 3
