TR4/4A Tach and Speed inner gaskets
Zitch
I have my dash apart and was cleaning the inside of the Speedo and Tach Glass. I noticed the inner glass gasket is cracked and falling apart.
Has anyone tried just a generic gasket about the same size from McMaster-Car?
I hear some gauge companies sell them at crazy prices but......
https://www.mcmaster.com/#5288t291/=12r75i1
wonder if this would work? $8 for 25, if it does I'll have some spares.
TR3driver
Great Pumpkin - R.I.P
IMO something that hard is going to make it really tough to get the bezel back on. You need something that can compress under the meager force you can apply.
I found some very soft tubing that worked well for me. Sorry, I don't have the details handy.
Brinkerhoff
I use a black strip caulk by 3M and roll it with my hands into an "o ring". It can be trimmed with a razor blade after installing the glass and bezel.
glemon
Maybe similar to what Brinkerhoff used, I just got some "rope caulk" at the local hardware store to replace a missing taillight seal on another car, basically a putty on a roll somewhere between 1/8" and 1/4" in diameter, it can be combined to make thicker, or rolled and stretched to make thinner. Tacky but not gooey, it would be easy to make into a compressible seal for the instruments I would think, stays soft and malleable. Wish I had tried it sooner seems like a viable option for many gasket and sealing issues where not exposed to engine heat or fluids. Only a few bucks.
Zitch
Zitch
I've used that 3m caulk rope on taillights. That is not something I want on the inside of my gauges. I'll keep looking for a softer gasket or try some smaller tubing like TR3 driver suggested
Roger
Bronze
I got some 3mm and 4mm sponge seal from eBay, exactly the right thing for the job. Comes from UK, but very quick.
You don't want caulk!
dklawson
As Randall said, you really don't want anything rigid like the backup ring at McMaster.
I have used window screen spline from the home center. There are several different sizes to pick from. Lowes and Home Depot don't always carry the same sizes and that gives you even more to pick from. The spline is tubular and compliant so it will fit between the glass and bezel.
You can also buy foam cord from various U.S. and U.K. sources. I have purchased it from Auto Electrical Spares in the U.K. A link is below but this is just for one size. I believe they have a couple of different diameters.
https://www.autoelectricalspares.co...rd-seal-x-1-meter-for-smiths-bezel-1294-p.asp
Auto Electrical Spares also sells some of the bezels and glass which might help you justify ordering from Europe.
Roger
Bronze
That's who I used. Good shop!
CJD
That looks like it...a very soft foam that you cut to length. Better price than nisongers too!
Roger
Bronze
As I wrote above, they also sell a 4mm size, which fits better on larger instruments.
Zitch
Zitch
However there are 2 gaskets on the glass. One toward the bezel and one toward the metal inner ring that looks like a paper gasket.
The gasket that was in the V of the chrome bezel has crumbled away and looked to be a caulk of some type. The other inner paper gasket is intact.
OK I see you can where you can use the caulk now or the 4mm foam.
But that inner paper gasket between the inner bezel and the glass is that available or does one have to cut out of paper gasket?
Popeye
Bronze
I made the rings from heavy construction paper and a circle cutter.
I echo the advice for Auto Electrical. I just ordered the flat o-rings that go between gauge and panel, as well as some foam cord to go between bezel and glass. (Note, the o-ring from Moss actually works decently well between bezel and glass for the speedo and tach, but does require some "futzing" to get it in place, as the or-ring diameter is a little too small.) The Moss o-rings are supposed to go between gauge and dashboard, but I found them to be quite thick, and make the gauge stand proud. I'll see how the Auto Electrical parts compare, and will report back.
I also ordered two of the "shovel" clamps to hold on the speedo and tach that were missing when I disassembled the dash. Expensive - $15 each, plus shipping! (Sourced from Anglo Parts, https://www.angloparts.com - no financial interest, etc.) I could not find these supplied anywhere else, except on ebay, at similar prices.
ronzet Tach and Speed-o-meter retaining brackets.... MG 15
B MGA Tach drive issue MG 1
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
Celtic 77 MGB Non working tach. MG 4
jackq Wanted Need a C Tach MG Classifieds 2
S Sticky Tach Spridgets 2
Joe Reed MGB Tach slow to wake up...why? MG 6
Lin Tach drive housing for BT7 Austin Healey 4
HealeyRick Tach Trouble Spridgets 2
W Tach wiring problems Jaguar 12
Marvin Gruber BJ7 tach cable location. Austin Healey 3
EWD TR6 ‘74 Tach Triumph 7
PAUL161 T-Series Lazy Tach MG 3
boxofparts MGB busy tach on 1979 MGB at 75 mph MG 3
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
J 1965 BJ8 Tach Austin Healey 3
longbridgehealey Alternator conversion and tach Austin Healey 9
Healey Nut Mechanical tach drive Austin Healey 2
Healey Nut Mechanical tach drive assembly Austin Healey 4
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
S TR2/3/3A tach cable lubricant Triumph 4
D BT7 tach question Austin Healey 8
5 Tach Drive Generator for a Bugeye Spridgets 2
I Tach help Spridgets 3
Marvin Gruber BJ8 tach Austin Healey 9
Superwrench Tach not working Austin Healey 6
JimTR4 TR4/4A Capping off redundant tach cable connection Triumph 0
W Use of original Tach Spridgets 8
A Need help wiring my tach Spridgets 11
Patrick67BJ8 Tach Hookup Instructions from Nisonger Austin Healey 23
S TR5/TR250 tach problems Triumph 2
J Hunting tach and back fire TVR 8
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
M Tach generator gearbox Spridgets 6
M Strange Healey Tach Austin Healey 9
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
busybrit Tach stops when flashers are turned on !! Jaguar 3
busybrit Electrical tach issue on Aston Martin DB5 Other British Cars 2
AngliaGT What Goes to the Left of the Tach? Spridgets 3
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
J How can I tell if I have a negative ground tach? Austin Healey 5
E TR4/4A Speedo v Tach cable Triumph 2
rjc157 tach goes crazy Austin Healey 8
Sopwith_Camel tach-less Spridgets 11
B Lazy Tach Austin Healey 2
J Tach drive housing eccentric Austin Healey 14
G MGB Tach and speedo rebuild. MG 3
Schroeders T-Series TF Tach Calibration - DIY? MG 3
Darwin Spitfire Help wiring up a tach Triumph 9
5 Tach Drive on Bugeye Austin Healey 10
