Tach stops when flashers are turned on !!
busybrit
I'm hoping someone can help me with my electrical gremlin.
Not a Jaguar, but you may have had a similar problem,, I'm working on a 1964 Aston Martin DB5 and both the fuel gauge and the rev counter work fine, but
the flashers and handbrake warning light do not.
When I move the flasher arm to the on position, "up or down," or pull up on the handbrake, the rev counter drops to zero and the fuel gauge to falls to empty.
When I take off the handbrake or put the flasher arm in the middle "off" position both the rev counter and fuel gauge do not come back on.
However, if I turn off the ignition, then restart the car, both the fuel gauge and the rev counter now work,,, until I move the flasher arm or handbrake!
Any ideas????
Geo Hahn
Mostly clueless but I will ask -- is the tach electronic (i.e. using ignition coil impulses) or simple electric (powered by a small tach generator, possibly on a camshaft)?
LarryK
Check grounds of each. Check the Red-Purple wires, if any on these circuits. Look closely at ignition switch as it does kill the cycle when used. If any electrical work has been done, recheck. Handbrake and turn signal flasher may have a connection as handbrake light may ground thru the brake switch. If you have a wiring diagrahm follow flow closely.
busybrit
busybrit
Problem solved, thought I'd let you guys know what it was. The flashers, handbrake warning light, fuel gauge and tach, all on the same circuit.
When the flashers or the handbrake warning light was activated the bulb/s called for more amps than the circuit was able to supply due to having a loose connection. The power draw resulted in sharing the reduced amps that was available, thus shutting down the whole circuit.
Thx Johnb
C Tach stops when panel lights are switched on Austin Healey 5
B MGA Tach drive issue MG 1
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
Celtic 77 MGB Non working tach. MG 4
jackq Wanted Need a C Tach MG Classifieds 2
S Sticky Tach Spridgets 2
Joe Reed MGB Tach slow to wake up...why? MG 6
Lin Tach drive housing for BT7 Austin Healey 4
HealeyRick Tach Trouble Spridgets 2
W Tach wiring problems Jaguar 12
Marvin Gruber BJ7 tach cable location. Austin Healey 3
EWD TR6 ā€˜74 Tach Triumph 7
PAUL161 T-Series Lazy Tach MG 3
boxofparts MGB busy tach on 1979 MGB at 75 mph MG 3
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
J 1965 BJ8 Tach Austin Healey 3
longbridgehealey Alternator conversion and tach Austin Healey 9
Healey Nut Mechanical tach drive Austin Healey 2
Healey Nut Mechanical tach drive assembly Austin Healey 4
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
S TR2/3/3A tach cable lubricant Triumph 4
D BT7 tach question Austin Healey 8
5 Tach Drive Generator for a Bugeye Spridgets 2
I Tach help Spridgets 3
Marvin Gruber BJ8 tach Austin Healey 9
Superwrench Tach not working Austin Healey 6
JimTR4 TR4/4A Capping off redundant tach cable connection Triumph 0
Zitch TR4/4A Tach and Speed inner gaskets Triumph 13
W Use of original Tach Spridgets 8
A Need help wiring my tach Spridgets 11
Patrick67BJ8 Tach Hookup Instructions from Nisonger Austin Healey 23
S TR5/TR250 tach problems Triumph 2
J Hunting tach and back fire TVR 8
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
M Tach generator gearbox Spridgets 6
M Strange Healey Tach Austin Healey 9
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
busybrit Electrical tach issue on Aston Martin DB5 Other British Cars 2
AngliaGT What Goes to the Left of the Tach? Spridgets 3
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
J How can I tell if I have a negative ground tach? Austin Healey 5
E TR4/4A Speedo v Tach cable Triumph 2
rjc157 tach goes crazy Austin Healey 8
Sopwith_Camel tach-less Spridgets 11
B Lazy Tach Austin Healey 2
J Tach drive housing eccentric Austin Healey 14
G MGB Tach and speedo rebuild. MG 3
Schroeders T-Series TF Tach Calibration - DIY? MG 3
Darwin Spitfire Help wiring up a tach Triumph 9
5 Tach Drive on Bugeye Austin Healey 10
