MGB Tach slow to wake up...why?
Joe Reed
I just watched a YouTube video of a very low mileage MGB LE for sale. When the saleslady starts the car the tach stays pegged on zero, and then "wakes up" a few seconds later. My car also does this...and has for the 20 years I've owned it. I don't remember if the '72 Midget I had back in the day did this, but there's a lot I don't remember from the 1970s. The only other MG I've owned was a '79 I sort of inherited but I only drove it once (it ran horribly) before Tony Barnhill came to get it. I never would have noticed if it had this same affliction.
This seems to be very common, but I've never seen an explanation of why this happens. Anyone with enough knowledge of these instruments know why this occurs?
I have no intention of trying to "fix" it. I find it to be sort of an endearing quirk. It's as if the car first says "Wait...let me finish waking up!"....then, a few seconds later tells me "OK, let's go!"
NutmegCT
If I recall, on my MGTD and my MGB, same thing happened The grease was old and "sludgy". Removed the old stuff, replaced with new grease, and all was well.
Tom M.
Platinum
I put up with that in the Elan for a while, got tired of tapping the thing and removed it to renew the lubricant. All better now.
Joe Reed
Joe Reed
I can tap mine to get it going, but it starts up without that after a few seconds....or if I rev the engine a bit. Not something I want to remove the speedo to fix!
B MGA Tach drive issue MG 1
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
Celtic 77 MGB Non working tach. MG 4
jackq Wanted Need a C Tach MG Classifieds 2
S Sticky Tach Spridgets 2
Lin Tach drive housing for BT7 Austin Healey 4
HealeyRick Tach Trouble Spridgets 2
W Tach wiring problems Jaguar 12
Marvin Gruber BJ7 tach cable location. Austin Healey 3
EWD TR6 ‘74 Tach Triumph 7
PAUL161 T-Series Lazy Tach MG 3
boxofparts MGB busy tach on 1979 MGB at 75 mph MG 3
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
J 1965 BJ8 Tach Austin Healey 3
longbridgehealey Alternator conversion and tach Austin Healey 9
Healey Nut Mechanical tach drive Austin Healey 2
Healey Nut Mechanical tach drive assembly Austin Healey 4
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
S TR2/3/3A tach cable lubricant Triumph 4
D BT7 tach question Austin Healey 8
5 Tach Drive Generator for a Bugeye Spridgets 2
I Tach help Spridgets 3
Marvin Gruber BJ8 tach Austin Healey 9
Superwrench Tach not working Austin Healey 6
JimTR4 TR4/4A Capping off redundant tach cable connection Triumph 0
Zitch TR4/4A Tach and Speed inner gaskets Triumph 13
W Use of original Tach Spridgets 8
A Need help wiring my tach Spridgets 11
Patrick67BJ8 Tach Hookup Instructions from Nisonger Austin Healey 23
S TR5/TR250 tach problems Triumph 2
J Hunting tach and back fire TVR 8
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
M Tach generator gearbox Spridgets 6
M Strange Healey Tach Austin Healey 9
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
busybrit Tach stops when flashers are turned on !! Jaguar 3
busybrit Electrical tach issue on Aston Martin DB5 Other British Cars 2
AngliaGT What Goes to the Left of the Tach? Spridgets 3
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
J How can I tell if I have a negative ground tach? Austin Healey 5
E TR4/4A Speedo v Tach cable Triumph 2
rjc157 tach goes crazy Austin Healey 8
Sopwith_Camel tach-less Spridgets 11
B Lazy Tach Austin Healey 2
J Tach drive housing eccentric Austin Healey 14
G MGB Tach and speedo rebuild. MG 3
Schroeders T-Series TF Tach Calibration - DIY? MG 3
Darwin Spitfire Help wiring up a tach Triumph 9
5 Tach Drive on Bugeye Austin Healey 10
C Tach stops when panel lights are switched on Austin Healey 5
