Dwell/Tach Hookup to Pos Ground with Petronix?
karls59tr
Bronze
I want to hook up my dwell/tach to my Pos Gr TR3 with Petronix but I dont want to fry anything. The green clip is supposed to connects to the -coil terminal and the black clip goes to - battery terminal. But this is a POS gr car so what would be the hook up here? My dyslexia strikes again. :smile:
TR3driver
Great Pumpkin - R.I.P
You're not likely to fry anything Karl, the meter is almost certainly protected against anything you could do wrong (except maybe laying it on the exhaust manifold :smile: ).
Because of the unusual way the positive ground Pertronix connects, I believe you want to use exactly the same connections for the dwell/tach. The green clip goes to the same coil terminal that has the lead from the Pertronix (which should be the "-" or "SW" terminal), and the black clip goes to the "-" battery terminal.
tahoe healey tach dwell meter Restoration & Tools 5
livinginthepast Positive ground tach/dwell meter hook up Spridgets 1
JPSmit Tach Dwell Meter Restoration & Tools 14
J Tach/Dwell meter Austin Healey 6
K TR2/3/3A The Distributor Dwell reading... Triumph 1
Lin Tachometer/Dwell Meter Austin Healey 10
K TR2/3/3A Point gap and dwell..... Triumph 12
C TR2/3/3A Dwell setting Triumph 11
S How to check Dwell on a MK I 3000? Austin Healey 27
DanLewis Electronically Adjustable Timing and Dwell Spridgets 7
R TR2/3/3A TR3A dwell Triumph 11
BOBBYR Positive ground dwell Austin Healey 23
chicken Is a Dwell meter worth it for setting points Austin Healey 10
BOBBYR Dwell meter choice? Austin Healey 1
H Dwell is Off, But Gap is Correct? MG 20
J TR2/3/3A Dwell angle on TR3A? Meaningful? Triumph 8
H TR6 TR6 dwell/points gap Triumph 4
Stinky I dug an old Dwell Meter,....Now what? Triumph 18
M dwell meter Austin Healey 5
B MGA Tach drive issue MG 1
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
Celtic 77 MGB Non working tach. MG 4
jackq Wanted Need a C Tach MG Classifieds 2
S Sticky Tach Spridgets 2
Joe Reed MGB Tach slow to wake up...why? MG 6
Lin Tach drive housing for BT7 Austin Healey 4
HealeyRick Tach Trouble Spridgets 2
W Tach wiring problems Jaguar 12
Marvin Gruber BJ7 tach cable location. Austin Healey 3
EWD TR6 ā€˜74 Tach Triumph 7
PAUL161 T-Series Lazy Tach MG 3
boxofparts MGB busy tach on 1979 MGB at 75 mph MG 3
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
J 1965 BJ8 Tach Austin Healey 3
longbridgehealey Alternator conversion and tach Austin Healey 9
Healey Nut Mechanical tach drive Austin Healey 2
Healey Nut Mechanical tach drive assembly Austin Healey 4
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
S TR2/3/3A tach cable lubricant Triumph 4
D BT7 tach question Austin Healey 8
5 Tach Drive Generator for a Bugeye Spridgets 2
I Tach help Spridgets 3
Marvin Gruber BJ8 tach Austin Healey 9
Superwrench Tach not working Austin Healey 6
JimTR4 TR4/4A Capping off redundant tach cable connection Triumph 0
Zitch TR4/4A Tach and Speed inner gaskets Triumph 13
W Use of original Tach Spridgets 8
A Need help wiring my tach Spridgets 11
Patrick67BJ8 Tach Hookup Instructions from Nisonger Austin Healey 23
S TR5/TR250 tach problems Triumph 2
