Austin Healey 100 BN2 fuel gauge not working
Martinld123
Bronze
Hope someone might help. My fuel gauge has been intermittent for a few years but now has finally stopped working. I have a negative ground car. At the sender to ground I get 1.27 volts. At the gauge I get 1.31 volts to ground so slight loss at sender. On battery side of gauge I get 11.78 volts to ground without engine running. All readings were with engine off. With both wires on gauge I get a resistance 21.4 ohms between both posts. I am hoping for a $57.00 sending unit problem and not a $499 gauge problem, lol. I am leaning toward the $57 solution. Any ideas? Thanks Marty
rossco
My BN-1 fuel guage is not working. How do I test the sending unit to make certain that's not the problem? Sorry to bust in on this thread but some of the responses may be related. Who does the Smith's gauges repair?
55modified
I will join, mine stopped working too. Guy up East rebuilds I forget name, he is easy to find. You can test gauge to see if it spikes. Google that. My problem has to be related to 63 year old cloth wiring. My new tank was installed with a new sending unit.
Brinkerhoff
The fuel tank needs to be grounded which is done through the steel fuel line since the tank sits on rubber pads. Grounding the hot lead to the sender will bypass it and should cause the gauge to read if the gauge wiring and gauge are ok.
dklawson
I have no experience with the specifics of the 100 fuel gauge. However, the gauge system is almost certainly Smiths/British-Jaeger magnetic.
On magnetic gauge systems it is imperative that the gauge case has a good ground and that the tank has a good ground. The sending units typically operated from low resistance = empty to high resistance = full. With the sending unit out of the car you can test the sending unit with a multimeter. Connect one probe to the sender flange or ground terminal, connect the other probe to the insulated sender terminal. Moving the float arm up and down should produce a resistance change... probably in the range of 0 to 90 Ohms. If you see a resistance change that goes to "infinite" somewhere along the travel, the sender resistance windings have an open. Repair is typically by replacement.
If you want to check the gauge, at the sending unit locate the green/black wire. With the ignition in the run position, disconnect the green/black wire from the sending unit. The gauge should go to (above) full. Now touch the bare end of the green/black wire to chassis ground (on the car, not the tank or sender). The gauge should go to (below) empty. If that doesn't happen, check that the gauge case has a good ground and repeat the test. If the gauge still doesn't respond you have a gauge issue to sort out.
All of this assumes you are getting 12V to the "B" terminal on the back of the gauge and that the green/black sending unit wire is securely attached to the gauge's "T" terminal.
Martinld123
Martinld123
Bronze
Doug thank you! I took the wire off the sending unit turned on key and the gauge showed full. Grounded wire to car frame and it went to empty. The new sending unit is on the way. You were a big help. Thanks Marty
dklawson
I hope you did not buy the sender prematurely. If the new sender does not fix the problem, be sure to run a dedicated ground wire between the fuel tank/sending unit and the car's chassis.
Martinld123
Martinld123
Bronze
Doug thanks for follow up. I ran out to garage to ground sending unit but gauge still not working. Wouldn't the fuel line ground the tank? Still looks like sending unit. thanks again, Marty
dklawson
I believe the original Petroflex (braid covered) fuel hoses were supposed to supply the ground connection to the tank. However, it's not unusual for owners to replace that with simple rubber hose and plain rubber won't conduct. That's why I suggested testing the gauge by grounding the green/black wire to the car's chassis and not to the tank. It's also why I suggested running a dedicated ground wire from the car's chassis to the sending unit and/or tank.
If adding the ground wire did not resolve the problem, I agree... your gauge works and the problem is almost certainly in the sending unit. I'm glad they don't appear to cost too much.
EDIT: Craig, thanks for posting that link. I carried out a similar modification on an early Mini fuel sending unit. Instead of using the coiled single-strand wire shown in the article you linked, I used a length of braided motor brush wire. That material is very similar to the ground wire that typically runs from the breaker plate to distributor housing in early Lucas distributors. It is made for high-flexing. If anyone wants to use fine-stranded motor brush wire for their sender, I suggest you tin all the other parts/surfaces first before soldering to the wire. The fine-stranded stuff will wick solder very quickly and loose its flexibility.
Martinld123
Martinld123
Bronze
Doug just installed new sender and it works great. I think I might have found the problem with plastic float filled with petrol, lol. Sender is older version with just one wiper on one side of coil. New one has wipers on both sides of coil to trap it but same plastic float. I never thought any plastic could survive long swimming in a lake of petrol 24/7. I am guessing 10 years for this float. I should have pulled it out of tank first to inspect but playing with 14 gallons of petrol once is enough for me as you know lots of garages burn down that way. I had lots of fire extinguishers around car and me, lol. Thanks, you made it easy. I always get great help here on British Car Forum. Marty
John Kuzman
I replaced the plastic floats with a brass float. Picked one up at the local Ford dealership. Ford number: C0AZ-9202B
dklawson
I am glad you got it working without mishaps.
The Ford float is a good substitute for the Smiths part. There is one caveat when using the Ford float. The Smiths float arms are coiled on the end to hold the float. Often the end of that loop has a sharp burr on the cut end. That sharp burr chan punch through the thin brass float where it did not punch through the plastic. Use a file to remove the sharp edge on the end of the loop and spread the loop a bit wider so it doesn't crush the Ford float.
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
dougie Austin-Healey 100 Documentary Austin Healey 3
H 100-6 Austin-Healey Austin Healey 7
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
S For Sale Austin Healey 100-4 Factory Parts Manual on CD/ROM Austin Healey Classifieds 0
S For Sale Austin Healey 100-4 Factory Workshop Manual on CD/ROM Austin Healey Classifieds 0
S For Sale Austin Healey 100-6 and 3000 Factory Service Manual on CD/ROM. Austin Healey Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
Z For Sale 1956 Austin Healey 100-4 race car for sale Austin Healey Classifieds 1
Z For Sale 1954 Austin Healey 100-4 BN1 Beautiful Restoration Austin Healey Classifieds 0
T For Sale 1959 Austin Healey 100-6 BN6 2.6L Race Car Austin Healey Classifieds 3
Z For Sale 1954 Austin Healey 100-4 Beautiful Restoration Austin Healey Classifieds 0
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
P Wanted Austin Healey 100-4 Bulkheads Austin Healey Classifieds 2
E For Sale 1955 Austin Healey 100 /4 rust free project car Austin Healey Classifieds 3
T Austin Healey 100 engine color Austin Healey 10
S For Sale Austin Healey 100-4 Grille Austin Healey Classifieds 2
S For Sale Austin Healey 100-4 Carpet Kit and Interior Panel and Trim Kit Austin Healey Classifieds 0
Vineyarder Austin Healey 100-4 brake line fittings Austin Healey 10
vette What is an Austin Healey 100-6 MM kit. Austin Healey 10
W Austin Healey 100-6 Sell or Restore? Austin Healey 5
L For Sale Austin Healey 100 literature for sale Austin Healey Classifieds 1
B Austin Healey 100/6 vin plate and serial number question Austin Healey 3
L Tinplate Austin Healey 100 model Austin Healey 3
pan Austin-Healey 100 BN1 Gears Austin Healey 5
F Great set of videos showing the superb resoration of a Austin Healey 100-6 - a must Austin Healey 3
AN6-TX New Book: Factory Original Austin-Healey 100-6 & 3000 Austin Healey 8
B Austin Healey 100-6 Bn4 Badge Number Austin Healey 17
C Help!!! Austin Healey 100-6 engine problem Austin Healey 2
H Austin-Healey 100, 100-6, 3000 Restoration Guide Austin Healey 14
cmc140 Austin-Healey 100 front splash pan / splash shield question. Austin Healey 8
E Austin healey 100 s car auction july 12 th Austin Healey 0
andrea Austin Healey 100/6 cross flow heater pipeclips Austin Healey 3
T A new Opportunity 1959 Austin Healey 100-6 Austin Healey 9
D Austin Healey 100-6 Compression Austin Healey 1
E Austin Healey 100 parts Austin Healey 5
M Mirrors '56 Austin Healey 100 4 Austin Healey 23
S Austin Healey 100 6 screw list Austin Healey 6
B Found: 1955 Austin Healey 100-4 Austin Healey 8
J Austin Healey 100 S Austin Healey 21
B Austin Healey 100-4 barn find! Austin Healey 23
Tony_Bowen Austin Healey 100-6 Stuck motor... Austin Healey 19
S Austin Healey 100 6 numbers Austin Healey 10
d_valentino Austin Healey 100 "Fitted Luggage" Austin Healey 6
d_valentino 1955 BN2 Austin Healey 100 Questions Austin Healey 39
