Austin Healey 100 6 numbers
Stuart1006
Member
Hi: I've I bought a Healey, that I think is a 1957 or 58 100-6. It is missing the information plaque in the firewall and I have not been able to locate the engine number. I do have a number from the title: C54641, but I do not know what does it represent: chassis or engine.
1. How can I get more information about the car? I own a 1953 MGTD and you can get all the manufacturing data (Chassis no., engine no., date of manufacture etc.)from a web site. Is there a similar site for Austin Healeys?
2. If not is there any way I can get this information?
Thank you very much.
Stuart J. Ramos
Keoke
Hi Ramos,
Sure we have a sight like that it just isn't located right around the corner. It is called the heritage trust and it is based in England. For a small fee [ www.heritage-motor-centre.co.uk/] they can tell you all you want to know about your car.---Keoke--- :wink:
Hey!!! Ramos, Have a buddy down there he owns a Grn BJ8 Healey but it is based here in the US with me "Bill Collins Texaspitbbq@hotmail.com" send him an E-Mail tell him Jorge in LA told you to call.---- :thumbsup:
healey106
Stuart - Best of Luck with your 100-Six.
I would recommend the first thing to do would be to check Derek Job's site
www.healeysix.net. It has everything you need to know about the early cars. If your car is # 54641 it was built in 12/57 or 01/58
Also check on the inside of the cockpit trim, if it is an early 100-six, that should provide the car body number.
jim :driving:
Legal Bill
Hey Jim, thanks for that link. I have been spending considerable time researching a 100-6 and that site helps confirm my thinking.
Best to you and Derek.
Bill
S
Stuart1006
Member
Hi: Thank you everybody for your excellent help, you really have been very helpful.
JIM: I belive you are right about the built date, I had calculated late 57 early 58. When you say "check on the inside of the cockpit trim": What do you mean? Where in the cockpit should I look?
Thank a lot again.
Stuart
John Turney
The number C54641 is an engine number, but during this period the engine numbers and car numbers would be the same. Thus, the car number would be BN4L-O-54641 if it is left-hand drive and has an overdrive. (A right-hand drive car without overdrive would be BN4-54641). 54641 puts your car in the first batch of 100-6s, and Jim is correct about the build date.
It should have the "6-port head" which means that the intake manifold is separate from the intake manifold and the carburetors are at an angle, rather than bolted directly to the head and vertical.
The engine number plate should be on the left-hand (carburetor) side, down low, toward the front.
John Turney
Stuart1006 said:
.... When you say "check on the inside of the cockpit trim": What do you mean? Where in the cockpit should I look?
The back side of the aluminum trim around the edge of the cockpit will have a body number stamped on it. It should be two 4-digit numbers. Each set of aluminum trim went with a specific car body.
healey106
Stuart - I can only speak for the Longbridge The trim only has printed the 4 digits related to the body #. Also you should be able to find this 4 digit # located on
1 - the splash pan
2 - hood latch bracket
3 - hood hinge bracket and
4 - trunk lid prop bracket.
Refer to the Anderson and Moment guide pp 67-68. per the book the first 4 digits relates to an Austin/Jensen accounting number.
If 54641 is the true car #, then your BN4 was one of the earliest BN4s built in Abingdon, since the last Longbridge car was #54285, per Clausager.
Have fun searching for the numbers.
jim :driving:
John_SouthAfrica
Hi Guys
I am John Reidy from South Africa. Having owned Healeys since 1966, I now find a problem I have never come across
I purchased a 100/6 and all I can find is an aluminum plate with the numbers 4178 and below to the right 179. This plate was on the firewall. On the reverse side of the plate are the number 4178 and again to the right but below 162. The number 4178 also appears on the bonnet release bracket.
What do these numbers mean and how can I trace the chassis number which will allow me to find out more details on the car.
Any help would be appreciated.
Regard
John
Tech396
I have C/E # 56846 that was built in Feb 1958 at Abingdon, Body # 7954, Your number C54641 will represent both Chassis and engine numbers.
Stuart J. Ramos
DerekJ
This is the second 100-Six on the list in three weeks to have been 'discovered'. This car is from exactly the same period as the last one. It is a six port head car with the old style Longbridge interior and fittings but probably one of the first 100-Sixes to be made at Abingdon.
Just like the other one it's engine and gearbox were probably painted in the dark 'Morris Green' colour and not the light green metallic.
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
dougie Austin-Healey 100 Documentary Austin Healey 3
H 100-6 Austin-Healey Austin Healey 7
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
S For Sale Austin Healey 100-4 Factory Parts Manual on CD/ROM Austin Healey Classifieds 0
S For Sale Austin Healey 100-4 Factory Workshop Manual on CD/ROM Austin Healey Classifieds 0
S For Sale Austin Healey 100-6 and 3000 Factory Service Manual on CD/ROM. Austin Healey Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
Z For Sale 1956 Austin Healey 100-4 race car for sale Austin Healey Classifieds 1
Z For Sale 1954 Austin Healey 100-4 BN1 Beautiful Restoration Austin Healey Classifieds 0
T For Sale 1959 Austin Healey 100-6 BN6 2.6L Race Car Austin Healey Classifieds 3
Z For Sale 1954 Austin Healey 100-4 Beautiful Restoration Austin Healey Classifieds 0
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
P Wanted Austin Healey 100-4 Bulkheads Austin Healey Classifieds 2
E For Sale 1955 Austin Healey 100 /4 rust free project car Austin Healey Classifieds 3
T Austin Healey 100 engine color Austin Healey 10
S For Sale Austin Healey 100-4 Grille Austin Healey Classifieds 2
S For Sale Austin Healey 100-4 Carpet Kit and Interior Panel and Trim Kit Austin Healey Classifieds 0
Vineyarder Austin Healey 100-4 brake line fittings Austin Healey 10
Martinld123 Austin Healey 100 BN2 fuel gauge not working Austin Healey 13
vette What is an Austin Healey 100-6 MM kit. Austin Healey 10
W Austin Healey 100-6 Sell or Restore? Austin Healey 5
L For Sale Austin Healey 100 literature for sale Austin Healey Classifieds 1
B Austin Healey 100/6 vin plate and serial number question Austin Healey 3
L Tinplate Austin Healey 100 model Austin Healey 3
pan Austin-Healey 100 BN1 Gears Austin Healey 5
F Great set of videos showing the superb resoration of a Austin Healey 100-6 - a must Austin Healey 3
AN6-TX New Book: Factory Original Austin-Healey 100-6 & 3000 Austin Healey 8
B Austin Healey 100-6 Bn4 Badge Number Austin Healey 17
C Help!!! Austin Healey 100-6 engine problem Austin Healey 2
H Austin-Healey 100, 100-6, 3000 Restoration Guide Austin Healey 14
cmc140 Austin-Healey 100 front splash pan / splash shield question. Austin Healey 8
E Austin healey 100 s car auction july 12 th Austin Healey 0
andrea Austin Healey 100/6 cross flow heater pipeclips Austin Healey 3
T A new Opportunity 1959 Austin Healey 100-6 Austin Healey 9
D Austin Healey 100-6 Compression Austin Healey 1
E Austin Healey 100 parts Austin Healey 5
M Mirrors '56 Austin Healey 100 4 Austin Healey 23
S Austin Healey 100 6 screw list Austin Healey 6
B Found: 1955 Austin Healey 100-4 Austin Healey 8
J Austin Healey 100 S Austin Healey 21
B Austin Healey 100-4 barn find! Austin Healey 23
Tony_Bowen Austin Healey 100-6 Stuck motor... Austin Healey 19
d_valentino Austin Healey 100 "Fitted Luggage" Austin Healey 6
d_valentino 1955 BN2 Austin Healey 100 Questions Austin Healey 39
