We've traced the two wires from the switch and cleaned connectors. Bulbs look OK. Took out the switch and cleaned it. When we push the button, nothing happens. Tested the two contacts on the switch for ohms and get continuity with switch off and same zero reading when button is pushed. I cut the two wires and touched them together and still nothing happens. Any suggestions?
