MGB MGB brake servo
nicknnora
Have a 79 B- it has excessive brake pedal travel. Brake's work fine (all new all around-no air in system) Is there a way to check brake servo?
Nunyas
Are the rear brakes properly adjusted?
I ask this particular question because I very recently found that the previous owners of my '76 B were using the hand brake adjustment nut to adjust the rear breaks, and subsequently the cable for my hand brake broke. Ever since then I have some pretty excesive pedal travel while bringing my B to a halt, because my rear brakes are now woefully out of adjustment. I'd personally check that first since it's pretty easy to do.
*note to self: must remember to order new rear shoes and rear brake adjustment tool
N
nicknnora
I adjusted the rear brake's to spec. with the same result. I also unhooked the servo & plugged the hose, the brake pedal is then heavey & the travel no better.
AlamedaMGB
I agree, sounds like air.. The servo doesn't add any flexibility to the pedal travel, there is a solid shaft that conects the pedal to the Master Cylinder.
If you had the MC off, you MUST bench bleed it. The pump method doesnt' have a long enough stroke to properly bleed the Master Cylinder in the car..
Good Luck
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
Celtic 77 MGB 1977 MGB Brake issues MG 8
drooartz MGB Swapping to dual SU on later MGB with brake booster MG 7
wkilleffer MGB MGB brake light switches lately MG 1
wkilleffer MGB brake light switches of late Restoration & Tools 3
J MGB Question on the brake warning light for 78 MGB MG 6
B T-Series MGB Brake Pressure Switch MG 2
S MGB-GT mgb gt brake caliper rebuild kit? MG 2
B MGB GT V8 brake pad part number Racing 1
G MGB '71 MGB brake lights MG 18
QuickSilver MGB 77 MGB - Turn Signal, Brake Lamp and Hazard Issues MG 22
R6MGS MGB MGB brake problems MG 14
glemon MGB MGB Brake Bleeding MG 14
Shinsen774 T-Series Hydraulic Brake Switch-Early MGB-Still a problem? MG 9
kyreb1862 MGB Hand Brake Problem 77 MGB MG 3
kyreb1862 MGB 1977 MGB Brake Master Cylinder Identification MG 7
kyreb1862 MGB 77 MGB Brake Booster Color MG 5
kyreb1862 MGB MGB Brake Booster Diagnosis MG 1
PAUL161 MGB MGB Rear Disc Brake Conversions MG 14
A MGB MGB Brake M/Cyl...Made in China MG 9
Scott_Hower MGB MGB - Left turn signal wont flash, brake light dim MG 16
G MGB '77 MGB Brake Master Cylinder MG 8
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 0
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
