Scott_Hower
Looking for some advice... car is a 73 MGB.
The left side rear turn signal refuses to flash and the brake and parking lights are VERY dim. All bulbs (all around) are fine. I thought I had bad grounds, so I ran a seperate ground to both L side bulb sockets. Still cannot get the L rear to flash. The right rear brake/flasher works fine.
The hazard flasher also works fine, front and back on both sides flash, although L side is dim.
Anyone have any ideas?
