Wedge Brake and Tail lights
JFS
Bronze
I have no power to rear tail and brake lights. I suspect the headlight switch. I remember reading an old post on the removal and cleaning of said switch but had no luck in searching.
poolboy
The brake lights shouldn't be on the same switch as the tail lights...the brake lights should come on even if the other lights are not on.
Turn the ignition key to ON and depress the brake pedal and see if the brake lights come on...If they don't, then check the bulbs and the ground connections to the bulb socket.
JFS
JFS
Bronze
Brake lights go on when the brake light switch is bypassed. New switch ordered to be delivered tomorrow. One problem solved.
Tail lights are more problematic. Light switch feeds fuse 7-8 and fuse 9-10. The former feeds right side and front parking light as well as right tail light. The latter feeds left side and front parking light as well as left tail light. All other left side lights work. One other right side does not. Neither tail light socket is receiving any voltage. Sockets and grounds are good. l'll trace the appropriate wire feeds.
Raymond Dim tail/ Brake Lights MG 32
R Brake & Tail Lights NONE! Austin Healey 3
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
bighealeysource Brake Master Cylinder Austin Healey 27
S TR2/3/3A Lockheed brake system Triumph 7
kodpkd Disc Brake Pad Installation Austin Healey 11
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
TomMull TR2/3/3A Parking brake: Lesson learned? Triumph 8
LAW75 BJ8 Brake Lines Austin Healey 2
