So, I was rather chagrined to discover that the brake lights are now inoperative of Baby Blue. Turn signals and running lights, though, are working fine. My guess is it is the brake pedal switch. Continuity and voltage testing seems to indicate that is the situation, but I'm having a hard time getting consistent results, which may be user error. My thought was to pull and inspect the brake switch and put current through it from an outside source and see if it is the problem. I sure hope I don't have to go wire tracing. :grief:
EDIT: Answered my own question. Once I pulled the brake switch and hit it with an external power source, it was clear that was the problem. It wasn't completely shorted, but only a fraction of the incoming voltage was making to the other side, hence the inconsistent results from the continuity and voltage testers while hooked up to the car.
