Bugeye Brake Lights
RonR
Folks,
What would be a possible cause of no brake lights or turn signal lights on a Bugeye, assuming that all the bulbs are functional and the wiring is correct?
Thanks
spritenut
Bad fuse, there are only 2.
Or a dirty fuse.
white-fuse-green wires is the signals. brake lights, and heater blower and gas gauge.
The other fuse is for the horn.
Key on for the lights to work.
R Bugeye disk brake conversion Spridgets 10
I Bugeye drum to disk brake conversion Spridgets 23
W Bugeye With Squealing Drum Brake Spridgets 5
Rut later brake rods on a Bugeye Spridgets 7
P Bugeye rear brake springs??????? Spridgets 5
P Bugeye front drum brake picture Spridgets 7
DanLewis Rear brake backing plate differences: Bugeye vs. later model MG Midget Spridgets 12
B Bugeye rear brake assy? Spridgets 15
DanLewis Bugeye rear brake upgrade - hubs now rubbing Spridgets 3
6 Rear brake banjo bolt/61 Bugeye Spridgets 3
I Bugeye hand brake cable questions Spridgets 3
I Bugeye hand brake help please Spridgets 8
E Bugeye Disc Brake Conversion Spridgets 2
I bugeye brake union thread size? Spridgets 2
I Help ordering brake lines for Bugeye Spridgets 7
Hairyone bugeye rear brake shoes Spridgets 5
I Bugeye front brake drum temp? Spridgets 2
drooartz Hand brake for late drums on a Bugeye Spridgets 17
drooartz Late brake back plates on Bugeye Spridgets 5
marcm Bugeye Wiring and Brake Line Diagrams Spridgets 0
E 60 Bugeye Disc Brake Conversion Spridgets 28
Steve P. Bugeye brake upgrade? Spridgets 4
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
