Bugeye rear brake upgrade - hubs now rubbing
DanLewis
After successfully upgrading to disc brakes on the front of my 59 Bugeye and replacing the MC with a 3/4" unit, I decided to go all the way and upgrade the rear drums to the later dual piston cylinder type. I bought all the parts from a later model Midget - backing plates, springs, e-brake links, and ordered new shoes, new cylinders, etc. Even bought new wheel bearing kits too.
I had the drums machined to remove 1/16" off the edge so they wouldn't rub against the backing plates. Did the changeover, but now the original hubs are rubbing against the backing plates!
Has anyone else had this problem? Is there a common preferred solution?
Dan
nomad
Yes, but don't remember what I did. Seems there is interferance with the shield that catches oil leakage and I do remember the wheel bolt heads hitting the brake cylinders. I rectified that by grinding them slightly. None of it was too severe though. Seems makeing up new E brake rods was more of a headache.
Kurt.
DanLewis
DanLewis
Hi Kurt and Kellysguy,
I had the same problem with the bolts hitting the wheel cylinder, but I think that was because the WC wasn't seated properly. I noticed that I could push the WC away from the hub with a little force, but once I got it seated properly and had the circlip firmly in place, I could no longer move it by pushing on it and the bolts no longer hit the WC.
The hub, however, continues to rub against the shield. I tried grinding down the shield a little and it seemed to help, but didn't want to go too far so it still rubs. I'm still running with the original Bugeye axles and hubs, so I'm beginning to wonder if the axles on the later midgets are maybe 1/16" longer, or maybe the differential housing is a little narrower, or if the hubs are a bit different. :crazy:
Dan
P Bugeye rear brake springs??????? Spridgets 5
DanLewis Rear brake backing plate differences: Bugeye vs. later model MG Midget Spridgets 12
B Bugeye rear brake assy? Spridgets 15
6 Rear brake banjo bolt/61 Bugeye Spridgets 3
Hairyone bugeye rear brake shoes Spridgets 5
Keith_M Bugeye rear leaf springs Spridgets 19
Gerard Bugeye bonnet and entire rear clip Spridgets 4
TulsaFred Bugeye Generator rear bush issue Spridgets 8
R Bugeye rear bumperettes Spridgets 8
Keith_M Bugeye beading and rear cowling Spridgets 9
R Bugeye rear wheel advice needed Spridgets 20
I Bugeye rear lights not working Spridgets 11
DanLewis Checking condition of rear springs on a Bugeye Spridgets 17
M Bugeye rear brakes Spridgets 3
TulsaFred Bugeye rear wheel cylinder replacement tips Spridgets 10
P BUGEYE REAR TUBE SHOCK CONVERSION Spridgets 0
Gerard Spax rear shocks on Bugeye Spridgets 12
I How do I remove a rear axle in a bugeye sprite? Spridgets 27
drooartz Source for Bugeye top - rear bar Spridgets 13
Trevor Jessie Bugeye rear ends 100-6 [the result video] Spridgets 12
Trevor Jessie Bugeye rear ends 100-6 [needs a bonnet] Spridgets 11
M Bugeye gearbox rear seal Spridgets 7
T BugEye - identifying rear axles[?] Spridgets 0
T Bugeye rear jacking point not including axle Spridgets 3
T Reference pictures of Bugeye rear suspension Spridgets 2
M Bugeye rear Spridgets 6
M Bugeye rear end noise Spridgets 14
T Bugeye rear bush question - bolt is stuck and am I Spridgets 12
T Correct rear bushings for 1960 Bugeye? Spridgets 5
longbridgehealey rear bugeye brakes for dummies Spridgets 11
Hairyone bugeye rear springs Spridgets 1
M Rear bugeye upgrade advice Spridgets 18
toysrrus Bugeye: "FRONT TILT OR REAR TILT"? Spridgets 16
drooartz Late rear brakes, Bugeye -- rods adjusted Spridgets 5
msoylemez Wanted: Original Bugeye Rear View Mirror Spridgets 12
M Bugeye rally spec rear springs? Spridgets 9
E Bugeye Rear Hub Removal Spridgets 5
Ohiobugeye Bugeye Rear Wiring Harness Route???? Spridgets 1
abarth69 Square body sprite with Bugeye rear bumpers Spridgets 14
I Bugeye hardtop rear window removal Spridgets 2
ncbugeye Bugeye Rear End questions Spridgets 8
Jayrz Bugeye rear onto square sprite? Spridgets 4
Atrus Bugeye rear overriders Spridgets 4
E Bugeye Wire Wheel Rear Spridgets 22
T Filling rear Bugeye shocks - any tips? Spridgets 7
jlaird The guy with the banged up Bugeye rear end Spridgets 2
Geo Hahn Bugeye Rear Axles Spridgets 6
Geo Hahn Bugeye Rear Wheel Studs Spridgets 2
