We have a Bugeye with a rear end noise that I am about to tear apart the rear to check out.
To describe the noise: A mid range consistant hum under load at highway speeds. Much more noticable when the top is on. Very much the same noise as driving your mini van with the small spare that is under inflated (done that). When you let off the gas or push in the clutch it goes away.
99 percent sure it is from the rear and not the gearbox. I am thinking a bad bearing or bearings, probably the pinnion bearing? Maybe worn gears?
Any ideas? Thank you
