bugeye rear springs
Hairyone
I recently fitted new 10 leaf rear springs. The arse was up in the air & really hard.
There's always more than one solutions, but this one works great:
Take the three top leaves & put them on the bottom. This lowers the car & makes it a little softer (more like the original springs).
Many thanks for this answer.
Excellent!
I had a similar solution. I remove some springs, and then used a wedge to get the ride height down where I want it. It is still about 1/4" higher than the front, but I think it will settle with time.
Keith_M Bugeye rear leaf springs Spridgets 19
P Bugeye rear brake springs??????? Spridgets 5
DanLewis Checking condition of rear springs on a Bugeye Spridgets 17
M Bugeye rally spec rear springs? Spridgets 9
Gerard Bugeye bonnet and entire rear clip Spridgets 4
TulsaFred Bugeye Generator rear bush issue Spridgets 8
R Bugeye rear bumperettes Spridgets 8
Keith_M Bugeye beading and rear cowling Spridgets 9
R Bugeye rear wheel advice needed Spridgets 20
DanLewis Rear brake backing plate differences: Bugeye vs. later model MG Midget Spridgets 12
I Bugeye rear lights not working Spridgets 11
M Bugeye rear brakes Spridgets 3
TulsaFred Bugeye rear wheel cylinder replacement tips Spridgets 10
P BUGEYE REAR TUBE SHOCK CONVERSION Spridgets 0
B Bugeye rear brake assy? Spridgets 15
DanLewis Bugeye rear brake upgrade - hubs now rubbing Spridgets 3
Gerard Spax rear shocks on Bugeye Spridgets 12
6 Rear brake banjo bolt/61 Bugeye Spridgets 3
I How do I remove a rear axle in a bugeye sprite? Spridgets 27
drooartz Source for Bugeye top - rear bar Spridgets 13
Trevor Jessie Bugeye rear ends 100-6 [the result video] Spridgets 12
Trevor Jessie Bugeye rear ends 100-6 [needs a bonnet] Spridgets 11
M Bugeye gearbox rear seal Spridgets 7
T BugEye - identifying rear axles[?] Spridgets 0
T Bugeye rear jacking point not including axle Spridgets 3
T Reference pictures of Bugeye rear suspension Spridgets 2
M Bugeye rear Spridgets 6
M Bugeye rear end noise Spridgets 14
T Bugeye rear bush question - bolt is stuck and am I Spridgets 12
T Correct rear bushings for 1960 Bugeye? Spridgets 5
longbridgehealey rear bugeye brakes for dummies Spridgets 11
M Rear bugeye upgrade advice Spridgets 18
toysrrus Bugeye: "FRONT TILT OR REAR TILT"? Spridgets 16
Hairyone bugeye rear brake shoes Spridgets 5
drooartz Late rear brakes, Bugeye -- rods adjusted Spridgets 5
msoylemez Wanted: Original Bugeye Rear View Mirror Spridgets 12
E Bugeye Rear Hub Removal Spridgets 5
Ohiobugeye Bugeye Rear Wiring Harness Route???? Spridgets 1
abarth69 Square body sprite with Bugeye rear bumpers Spridgets 14
I Bugeye hardtop rear window removal Spridgets 2
ncbugeye Bugeye Rear End questions Spridgets 8
Jayrz Bugeye rear onto square sprite? Spridgets 4
Atrus Bugeye rear overriders Spridgets 4
E Bugeye Wire Wheel Rear Spridgets 22
T Filling rear Bugeye shocks - any tips? Spridgets 7
jlaird The guy with the banged up Bugeye rear end Spridgets 2
Geo Hahn Bugeye Rear Axles Spridgets 6
Geo Hahn Bugeye Rear Wheel Studs Spridgets 2
