Bugeye rear brakes
markberry
Hi All,
After taking the whole summer and fall off from working on the Bugeye restoration, I'm finally back on it. the front suspension parts just came back from the powdercoater and now I'm disassembling the rear axle to send it off for powdercoating. Anyway I came up with a few questions I'm sure most of you will know the answer to:smile:
What is the proper tool for taking the brakes apart(a picture would be nice)?f You know that spring, plier thingy...I bought one but it didn't seem to be of much use. I was able to get the smaller spring off with a pair of pliers but the bigger spring I just left attached and wiggled the shoes off their mount locations until the spring relaxed enough to pull the shoes out. Also, I have a brand new, in the box, set of brake shoes, but they have the part number associated with the later model brakes. will those fit on the Bugeye setup anyway? If not does anyone want them?
thanks everyone!
Mark
racingenglishcars
It seems you used the correct method for removing the brake shoes.
I used long-nose vice grips to reinstall.
If your rear brakes are of original type, the shoes should have a small hole at the contact point to the adjuster.
kirksauto
Early and late shoes are not interchangeable. The cut off for the early is Sprite HAN6-20544 and Midget GAN1-13554. Early are GBS819 aka 182-140 later are GBS834 aka 182-175.
M
markberry
Thanks!
longbridgehealey rear bugeye brakes for dummies Spridgets 11
drooartz Late rear brakes, Bugeye -- rods adjusted Spridgets 5
Keith_M Bugeye rear leaf springs Spridgets 19
Gerard Bugeye bonnet and entire rear clip Spridgets 4
TulsaFred Bugeye Generator rear bush issue Spridgets 8
R Bugeye rear bumperettes Spridgets 8
Keith_M Bugeye beading and rear cowling Spridgets 9
R Bugeye rear wheel advice needed Spridgets 20
P Bugeye rear brake springs??????? Spridgets 5
DanLewis Rear brake backing plate differences: Bugeye vs. later model MG Midget Spridgets 12
I Bugeye rear lights not working Spridgets 11
DanLewis Checking condition of rear springs on a Bugeye Spridgets 17
TulsaFred Bugeye rear wheel cylinder replacement tips Spridgets 10
P BUGEYE REAR TUBE SHOCK CONVERSION Spridgets 0
B Bugeye rear brake assy? Spridgets 15
DanLewis Bugeye rear brake upgrade - hubs now rubbing Spridgets 3
Gerard Spax rear shocks on Bugeye Spridgets 12
6 Rear brake banjo bolt/61 Bugeye Spridgets 3
I How do I remove a rear axle in a bugeye sprite? Spridgets 27
drooartz Source for Bugeye top - rear bar Spridgets 13
Trevor Jessie Bugeye rear ends 100-6 [the result video] Spridgets 12
Trevor Jessie Bugeye rear ends 100-6 [needs a bonnet] Spridgets 11
M Bugeye gearbox rear seal Spridgets 7
T BugEye - identifying rear axles[?] Spridgets 0
T Bugeye rear jacking point not including axle Spridgets 3
T Reference pictures of Bugeye rear suspension Spridgets 2
M Bugeye rear Spridgets 6
M Bugeye rear end noise Spridgets 14
T Bugeye rear bush question - bolt is stuck and am I Spridgets 12
T Correct rear bushings for 1960 Bugeye? Spridgets 5
Hairyone bugeye rear springs Spridgets 1
M Rear bugeye upgrade advice Spridgets 18
toysrrus Bugeye: "FRONT TILT OR REAR TILT"? Spridgets 16
Hairyone bugeye rear brake shoes Spridgets 5
msoylemez Wanted: Original Bugeye Rear View Mirror Spridgets 12
M Bugeye rally spec rear springs? Spridgets 9
E Bugeye Rear Hub Removal Spridgets 5
Ohiobugeye Bugeye Rear Wiring Harness Route???? Spridgets 1
abarth69 Square body sprite with Bugeye rear bumpers Spridgets 14
I Bugeye hardtop rear window removal Spridgets 2
ncbugeye Bugeye Rear End questions Spridgets 8
Jayrz Bugeye rear onto square sprite? Spridgets 4
Atrus Bugeye rear overriders Spridgets 4
E Bugeye Wire Wheel Rear Spridgets 22
T Filling rear Bugeye shocks - any tips? Spridgets 7
jlaird The guy with the banged up Bugeye rear end Spridgets 2
Geo Hahn Bugeye Rear Axles Spridgets 6
Geo Hahn Bugeye Rear Wheel Studs Spridgets 2
