brake pedal to the floor
chickentender
Member
i was driving my 60 BT7 the other day and all of a sudden i have no brakes with the pedal going to the floor. pump it again and i have brakes. it happened a couple of times on that drive and hasnt happened the next few drives. when it happened, i assumed it must be the master cylinder and was going to take it in for repair but it hasnt happened on the last two outings. the brake fluid cannister is full. any suggestions?
Master cylinder is my guess. When you push the pedal, fluid is going around the rubber cup instead of being pushed to the wheel cylinders. Check for dripping on the cabin side of the fire wall under the carpet. If you still got lots of fluid in the reservoir, there isn't a leak. If you had a wheel cylinder leak you would see fluid on the inboard side of the tires and the fluid level would go down.
Not real difficult to replace. Moss got their act together with the master cylinders now. Caution when bleeding. I over tightened one of the bleeder valves and stripped the threading. Got effective but spongy brake until I discovered the failure (spotted the fluid in the tire). Very hard to find Castrol LMA these days. This is a good time to flush out all the fluids including the clutch. Clutch slave is a real bitch to get to but do able.
Definitely agree with Elrey!
Keoke
Roger P. Main
It could be the spring in the master cylinder that closes off the line to the fluid reservoir. If the spring is broken, as happened on the clutch master cylinder of my Triumph TR-3A, which uses the same Girling master cylinder as on your Healey, way back in 1963, fluid will be forced back into the reservoir, instead of to the brake calipers/wheel cylinders, when your step on the brakes. I was told back then to use two springs, which will guarantee that breakage of one of the springs will not cause problems. The spring is highly tempered and very brittle, and can break without warning. I had to drive all the way from New York City to Washington, D.C., with a clutch that would not disengage back then. I forced the gearbox into fourth gear and stalled the engine every time I stopped. I then restarted the engine with the gearbox in fourth gear and the good, old, tractor engine the Triumph had drove right off. Try that with any modern car with a manual transmission.
why
Same very intermittent work-not work with no loss of fluid in my Etype clutch, rebuilt master cylinder now just fine.
Jay
'65 3000
N Brake pedal to the floor Austin Healey 13
F Excessive Brake Pedal Travel Austin Healey 3
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Sopwith_Camel MGB pulsing brake pedal MG 10
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
bighealeysource Soft Brake Pedal Austin Healey 7
S Receding Brake Pedal Austin Healey 32
K Midget Brake Pedal Question Spridgets 2
D TR2/3/3A clutch/brake pedal question Triumph 4
steveg "Sticking" the brake pedal Austin Healey 3
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
Michael Oritt Brake pedal contact or mercury switch Austin Healey 19
H BN1 Brake Pedal Hitting The Downpipe Austin Healey 9
Gearhead_Garage Brake Pedal Feel Austin Healey 24
R Low Brake Pedal Austin Healey 9
Joe_Healey Brake Pedal Rod Painted or Natural Austin Healey 14
T TR2/3/3A soft brake pedal on TR 3 Triumph 5
I TR2/3/3A Clutch and brake pedal assembly problem Triumph 4
PatGalvin TR2/3/3A Brake and Clutch pedal to MC adjustments? Triumph 4
H TR4/4A Soft Brake Pedal Triumph 3
PatGalvin TR2/3/3A Brake MC Bracket and pedal assembly install Triumph 24
angelfj1 TR5/TR250 Brake Pedal return spring Triumph 2
K TR2/3/3A Brake and Clutch MC pushrod/pedal bolt stops? Triumph 2
eschneider machine gun brake pedal Other Cars 3
T Soft brake pedal on BJ8 Austin Healey 3
V TR2/3/3A TR3A Brake Pedal - Too Much Travel Triumph 6
W TR6 TR6 brake pedal drip Triumph 12
R TR2/3/3A TR 3a brake/clutch master cylinders/pedal movement Triumph 4
CJD Brake/Clutch pedal adjustment Triumph 29
K Brake pedal doesn’t move mcylinder didn't fix Triumph 7
J Brake pedal cover removel? Triumph 5
J Brake/clutch pedal frozen Triumph 18
livinginthepast Disc brake conversion - soft pedal Spridgets 8
TR4 Brake Pedal Travel Adjustment Triumph 18
S BN1 clutch and brake pedal bracket Austin Healey 3
go_inbroke Brake pedal Triumph 12
Thor Brake light, do you have to remove pedal box? Spridgets 2
LuckyLuke 100-4 brake / clutch pedal seals not available Austin Healey 3
D No play in brake pedal - what a drag? Triumph 7
Randy Harris Brake Lights Work Only With Heavy Pedal Pressure Austin Healey 12
B gas, Brake, Clutch Pedal covers? Spridgets 8
saabmp3 weak brake pedal Spridgets 5
J Newbie - Soft Brake Pedal Spridgets 14
B XJ12L 1975 SOFT BRAKE PEDAL Jaguar 11
AUSMHLY brake pedal push rod adustment - YIKES ! Austin Healey 9
tr6web TR6 TR6 leaking at brake pedal Triumph 12
W Mystery of the re-occuring soft brake pedal Austin Healey 10
6 Brake Fluid Spridgets 4
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
