Healey 100 Front Wheel Bearing replacement
Healey 100
Healey friends:
Is it possible to replace the two ball bearings on the front hubs of the 100 with a tapered set? A friend with a 100-6 lost a front wheel when the ball bearings failed and I think the tapered set might be more durable and safer.
Anyone have any experience with such a conversion?
I do not know the answer to your question, but it is possible to lose the hub with tapered bearings too; my brother proved it.
zblu
Healey 100,
I seem to remember doing this about 30+yrs ago, from memory I found some "Timken" brand bearings that fitted, since then I have restored the car back to original including all its deficiencies
pan
Tapered Roller bearings were fitted to big Healeys from the BN2 onwards, so the 100/6 which lost its wheel would have had the later type of wheel bearing.
The parts list shows different part numbers for the stub axle between BN1 & 2, so maybe it isn't a simple change of bearing type. Tapered bearings also require shims on the bearing spacer to achieve the correct tension. According to the BN2 supplement in the shop manual, the shimmed spacer seems to have been fitted only to later BN2s.
healeynut
If you have a BN2, you already have tapered roller bearings.
If you have a BN1, you will have ball bearings. If it does concern you, you should go and buy a set of the original thrust ball bearings they used, which you can get from David Nock at British Car Specialists. I suggest this because it wouldn't suprise me if someone replaced the original ball bearings with standard ball bearings which are unsafe in this application. The original style thrust ball bearings can handle plenty of lateral load, although racing is probably not a good idea with these.
cmc140 Austin-Healey 100 front splash pan / splash shield question. Austin Healey 8
M Healey 100-4 Front Spring Stiffness Austin Healey 2
Editor_Reid Healey 100 Front Springs Austin Healey 7
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
R Healey 100 Dipstick Stuck Austin Healey 12
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
Guido36 Webers on a Healey 100 Austin Healey 6
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
C What to do with my late father's Healey 100 Austin Healey 5
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
B Overcooling Healey 100 Austin Healey 13
Editor_Reid Healey 100 Chassis Dimensions Austin Healey 5
Martinld123 Healey 100 BN2 Water Pumps Austin Healey 9
dougie Austin-Healey 100 Documentary Austin Healey 3
H 100-6 Austin-Healey Austin Healey 7
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
Guido36 Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
S For Sale Austin Healey 100-4 Factory Parts Manual on CD/ROM Austin Healey Classifieds 0
S For Sale Austin Healey 100-4 Factory Workshop Manual on CD/ROM Austin Healey Classifieds 0
S For Sale Austin Healey 100-6 and 3000 Factory Service Manual on CD/ROM. Austin Healey Classifieds 0
Lin Spruce Green Healey 100 Austin Healey 17
G For Sale Healey 100 windscreens for sale Austin Healey Classifieds 2
N Healey 100/4 from the Bahamas Austin Healey 8
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
C For Sale Healey 100 for sale Austin Healey Classifieds 3
Z For Sale 1956 Austin Healey 100-4 race car for sale Austin Healey Classifieds 1
Z For Sale 1954 Austin Healey 100-4 BN1 Beautiful Restoration Austin Healey Classifieds 0
T For Sale 1959 Austin Healey 100-6 BN6 2.6L Race Car Austin Healey Classifieds 3
Z For Sale 1954 Austin Healey 100-4 Beautiful Restoration Austin Healey Classifieds 0
Z For Sale 1955 Autsin Healey 100-4 BN1 and 1956 100-4 Race car Austin Healey Classifieds 0
W Healey 100 dip stick Austin Healey 16
W Healey 100 Overdrive stopped working Austin Healey 15
BN6 Healey 3000 and 100/6 Factory Hardtops serial numbers Austin Healey 5
J For Sale Healey Books: Anderson/Moment Restoration Guide; Robert Bentley; 100-6/3000 Factory Austin Healey Classifieds 7
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
P Wanted Austin Healey 100-4 Bulkheads Austin Healey Classifieds 2
E For Sale 1955 Austin Healey 100 /4 rust free project car Austin Healey Classifieds 3
T Austin Healey 100 engine color Austin Healey 10
S For Sale Austin Healey 100-4 Grille Austin Healey Classifieds 2
S For Sale Austin Healey 100-4 Carpet Kit and Interior Panel and Trim Kit Austin Healey Classifieds 0
S For Sale FOR SALE BN1 100-4 Healey Perspex Side Screen windows [California, USA] Austin Healey Classifieds 2
D Healey 100 issues Austin Healey 15
Vineyarder Austin Healey 100-4 brake line fittings Austin Healey 10
Martinld123 Austin Healey 100 BN2 fuel gauge not working Austin Healey 13
vette What is an Austin Healey 100-6 MM kit. Austin Healey 10
