For what I consider a proper repack is removal, cleaning of bearing and hub, repack, replace. The bearings are easily removed by knocking them out from the other side. Tap a little in one place, then again directly across from there. Pay attention to which side faces out. Both bearings are directional. Remove, clean and repack one bearing at a time. IIRC, they come aprt easily too, so watch how hard you tap it out and be ready to catch bits with your free hand.
Once clean, remove the center spacer, taking note of which way it is facing. Clean it and oput it to the side in relation to how it went in. Same thing w/ the bearing. once everyhting is out, clean out the hub. Mineral sprints is usually what's used, but gas and diesel are cheaper.
To repack, Lisle makes a power packer w/ grease supplied by a grease gun. That's what I usually use. To hand pack, I hold the bearing in one hand w/ my thumb covering the center hole. Scoop some grease out with the other hand, wipe it on the area your thumd is pointing at, then push it through the bearing with the palm of your hand. Slide your palm acrioss the bearing while doing this. it's very natural and you'll get the hand of it. Do this till grease comes out the other side. You could disassemble the bearing, but that's a pain and east to loose lose balls.
Once both bearings are packed, smear grease around the innner part of the hub cavity from the rear, place the spacer in, fill in the area around it w/ grease, install the rear bearing, place some grease around the outter edge, install seal, wipe off excess. PLace hub on spindle ( which should have already been cleaned), fill any empty cavity with grease, place outter bearing in, smear around the edge, replace washer, nut and pin. I put a little grease in the cap too. The idea is to have a ready supply of grease on either end of each bearing but not too much.
I use EP high moly grease on all the bearings on the enduro car. Same stuff can go in CV's too. Supposedly you'r not supposed to use moly on ball bearings. Well, the car ran 400 miles w/ a top speed of 150 for 6 hours with no problems. This is how and what I do, YMMV. I'm sure someone here might have simpler way of doing this. Hope this helps.
