Front Wheel Camber Setting
BG 62AH
Hi Guys, I am probably asking about a topic that has been discussed a whole bunch of times ... here’s my story and question. I have been using an old set of wheels (48-spoke) and oversized tires ( 205 70 R15). When I setup my suspension I used the Moss bushings and set the camber to +1 degree. With the oversized tires I have gotten a lot of wear on the outer edge of tires.
Fast forward, I recently bought new MSWs (15 x 5), and 185 70 R15 tires all set to mount with a new set of hubs.
I wanted to ask for a recommendation on what the camber should be. Didn’t want to burn up the new tires.
Any suggested thoughts on things that worked for others would be really appreciated.
Thank you!
Bill
vette
You’ve pushed the top of your tires out to one full degree and installed wider tires; it’s no wonder you're wearing the outside edges.
As BoyRacer said, set your camber to zero and reset your toe-in.
Keoke
DO U fellas recommend zero at full load????
vette
Keoke, I think that’s a very technical question. I think it is relative to his intended use. How often will he be at ‘full load’? I definitely don’t think he needs 1 degree of positive.
Keoke
Well Vette yeah but:
I simply meant do it simulating a driver only or that with a passenger which ever is his predominate use.
1 degree of positive is a bit much i would say too.
B
BG 62AH
Hi Guys, I basically drive the car very conservatively. Car shows, club meetings, and local weekend cruises. A passenger sometimes. I did all the restoration work myself (except for the paint), so I almost never drive the car hard.
My plan is to bring the camber closer to 0, and I am going to check the camber as suggested above. I also bought new hubs from Moss.
I really appreciate everyone’s suggestions. The BCF forum has been really helpful!!
Thank you
Bill
bthompson Relationship of bachelor lean to front wheel camber? Spridgets 5
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
P 100/6 Front Wheel Alignment Austin Healey 10
K TR2/3/3A Front wheel bearing felt seals too large? Triumph 9
Z 3000 Front Wheel Bearings Austin Healey 3
K TR2/3/3A Greasing the Front Wheel Hubs? Triumph 9
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
A Front wheel bearing issues Austin Healey 11
Rob Glasgow Front Wheel Bearingsknow Austin Healey 4
TRclassic3 TR2/3/3A Front wheel bearing adjustment Triumph 5
J TR2/3/3A Outer Front Wheel Bearing Triumph 22
K TR2/3/3A Front wheel hub "felt" again? Triumph 2
R Front wheel bearing - end float Austin Healey 40
K TR2/3/3A Front hub wheel bearing nut? Triumph 1
KVH General TR Front Wheel Bearing Felt Seal Direction Triumph 9
KVH TR4/4A Front Wire Wheel Hubs Differ from Disc Hubs?? Triumph 5
AHS TR2/3/3A Residual brake pressure valve - how much front wheel drag? Triumph 18
Jim_Gruber New MOSS Tapered Front Wheel Bearings - WTH are the instructions Spridgets 16
G TR4/4A Front Wheel Bearing Seal Triumph 19
N Front wheel bearings?? Spridgets 8
4tecdog BJ8 front wheel alignment Austin Healey 11
Jeepster Front wheel tracking-toe in Austin Healey 21
pan Front wheel bearings [BN1] Austin Healey 6
BN6_2197 Front Wheel Clearing of BN7 Austin Healey 35
M BN1 front wheel bearings Austin Healey 5
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
C TR2/3/3A Front wheel bearings Triumph 8
charleyf TR2/3/3A Front wheel bearing--inner tr3 Triumph 4
T TR2/3/3A Front wheel bearings direction and torque Triumph 1
S Problem removing front wheel bearing retaining nut Austin Healey 9
N Spitfire Front wheel bearing seal??? Triumph 11
Jim_Gruber Removing front wheel bearings from hub Spridgets 6
K TR2/3/3A Front wheel bearing grease seal with felt packing? Triumph 4
7 General TR Chirping front wheel bearing Triumph 6
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
G MGB Front Wheel Bearings MG 2
D Reinforced Front Wheel Arches Spridgets 35
P Bugeye Front Wheel Bearings? Spridgets 1
Morris Front wheel bearing installation Spridgets 4
Morris Front wheel bearings Spridgets 9
Scotsman TR2/3/3A tr3 front wheel hub stud removal Triumph 2
N Front Wheel Bearings?? Spridgets 4
Rut Front wheel bearings [again] Spridgets 12
hondo402000 TR6 TR6 front end alignment and wheel balancing Triumph 4
TulsaFred Front wheel bearing grease packing Spridgets 26
R 5mm wheel spacers on front when switching Minilite Triumph 2
R TR 3b front wheel bearings Triumph 5
