Post-War Other Front brakes on the Roadster
trrdster2000
This will be the least bit of help to the masses of any article ever added to BCF. Been really busy over the last year or so and the victim which has suffered is my Roadster. It got me back by peeing all it’s brake fluid on my new garage floor. Granted the wheel rubbers had been in there over 20 years. After taking all apart and as no movement was seen for a year or so, the shoes were fine. The wheel cylinders looked OK and a few seconds with a hone cleaned it right up.
Now where do you get a couple of kits for a ’49 Triumph. They are the solid kind(cups) and measure 1 and 3/8 inch. They were what is called at the time Static brakes. A spring was between the cups, keeping a small amount of pressure on the shoes. Now for the purpose of this write up. NAPA part # UP 857 and they never worked better and $2 each. So for all the Roadster owners, there you go. Oh, I also used the Valvoline Syn Tech, never had a problem in the cars using any rubbers, others my have.
Wayne
Jerry
There are two of these roadsters in our club. They both have brake problems. IE: they don't work well. They bled and bled and still there are air bubbles showing up in the system. They have had the masters rebuilt, but still issues. Is your cure above related to air in the system?
Jerry
trrdster2000
trrdster2000
Jerry, these masters are just the opposite of all masters ever built. The fluid is moved by the shaft on the brake pedal expanding the fluid as it goes into the space of the master void. Do not pump to expel the air, slowly push the pedal down as you open the bleeder, close off and release slowly. Only after getting a good bit of pressure do you hold and release the bleeder one time. I found going to the front right wheel first was best, just the opposite of most cars where you start at the furthest wheel.
Hope this will help.
Wayne
trrdster2000
trrdster2000
A quick THANK YOU to Paul for the Ebay site. OK, for now, but you never know.
Wayne
trrdster2000
trrdster2000
Jerry, I talked to my son, works for Intel in Seattle and he went to the show and didn't see any Roadster last weekend. Did they not get the brakes bleed???
Wayne
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
K TR2/3/3A Sticking front brakes? Triumph 9
K TR2/3/3A The flexing front spindle and no brakes syndrome? Triumph 5
John_Mc TR6 Front brakes won't release Triumph 20
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
C 100-6 front drum brakes? Austin Healey 36
C Wanted 3000 Front Disc Brakes Austin Healey Classifieds 4
C For Sale BN1 Front Drum Brakes assemblies and hubs for sale Austin Healey Classifieds 0
P Front drum brakes - fluid lines Austin Healey 12
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
C Value of BN1 Original Front Drum Brakes? Austin Healey 4
BN6_2197 Disassembling BN6 Front Brakes Austin Healey 14
R BJ8 Front Brakes drag some Austin Healey 9
T TR2/3/3A TR3A front brakes Triumph 2
mgedit TR2/3/3A Front Drum Brakes 56 TR3 Triumph 2
D TR6 1976 TR6 Front Brakes & Shocks Triumph 3
M Stuck front brakes? Spridgets 8
M Front brakes are sticking Spridgets 33
C Bugeye Disc Front Brakes FORUM Navigation Questions 0
C Bugeye Disc Front Brakes Spridgets 4
coj 1960 Healey 3000 front and rear brakes Austin Healey 2
bighealeysource front disc brakes conversion for 100-4 Austin Healey 21
O TR2/3/3A 1960 TR3 Front Brakes Triumph 2
Stewart Dragging front brakes MG 7
B front disc brakes- 66 sprite Spridgets 8
RickB Front brakes seizing - what's with that? Spridgets 23
M Slight bind in front brakes Spridgets 7
R Front Brakes... Spridgets 7
sparkydave Dragging front brakes Spridgets 4
T Check list to convert to front disc brakes Spridgets 9
T Front disc brakes make a big difference? Spridgets 5
T Time to redo all my brakes and front suspension... Triumph 14
S TR2/3/3A tr3 front brakes hoses Triumph 9
drooartz Installing front suspension/brakes - review Spridgets 1
zschicago my first Healey and questions about front brakes Austin Healey 10
v8mgbal front brakes Spridgets 9
M Difference between MK IX and XK 150 Front Brakes? Jaguar 6
Brosky Front Suspension & Brakes -Done Triumph 5
N TR6 Clip wires on front brakes for TR6 Triumph 9
eejay56 BMW 320i front brakes locked up Other Cars 8
1 front brakes Spridgets 3
19_again leak front brakes MG 6
M front brakes Spridgets 12
M front brakes Austin Healey 3
jmwuva05 Front drum brakes. Spridgets 2
ncbugeye Front wheels won't spin, dsic brakes binding? Spridgets 13
zimmy front disk brakes Spridgets 9
T TR4/4A Early TR4 - Front Brakes Triumph 3
zimmy front brakes and calipers Spridgets 3
R TR6 TR6 front brakes Jack Drew Triumph 13
