front brakes
v8mgbal
hello all, hope someone can shed some light on my problem,finally got my 74 midget out on the road and drove about 40 mile round trip, by the time I got home the front brakes were almost locked up, I rebuilt the calipers about a month ago drained and flushed the lines at that time and used silicone fluid and new pads, also installed a new mc, any ideas would be greatly appreciated. thanks alan
GeeBee1
Alan
It sounds like the flex lines\rubber hoses to me.
Glen_B
Improper adjustment of the return for the brake master piston, or plugged drain-back valve in the brake master.
Glen
bugimike
I would tend to agree with GeeBee1! I have experienced the same problem. The hoses looked good on the outside, but had collapsed internally! Glen could also be correct if adjustments had been made to the master push rod, but if not I would definitly suspect the hoses!
v8mgbal
v8mgbal
sorry, I did not mention that i replaced all the lines. also after i pulled the car back into the garage and jacked up the front of the car and it cooled down they spun just like there was never a problem.
Sopwith_Camel
what just happend to me was that the brake light switch was too far in and that kept the brakes from releasing all the way
cheery
steve
v8mgbal
v8mgbal
thanks for the info, it could be the switch, it is screwed in pretty far i will check it out, any other ideas.
healeyboz
Okay,
This is a huge debate and I have steered bake to synthetic. Another can of worms is about to be opened, but take it for what it is worth.
Supposedly silicone brake fluid can swell the rubber bits inside the system and cause your symptoms. i.e. lock the calipers up.
I have had MANY problems with my brake build, trying to use silicone. Everyone I have talked to, that rebuilds these brakes, will not warranty if silicone is used.
GeeBee1
Barry
I have used it for over 25 years and never had a problem, I guess that I am really lucky :wink:
healeyboz
I here ya. I still love everything about it. Just telling you what everyone else says. The "experts".
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
K TR2/3/3A Sticking front brakes? Triumph 9
K TR2/3/3A The flexing front spindle and no brakes syndrome? Triumph 5
John_Mc TR6 Front brakes won't release Triumph 20
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
C 100-6 front drum brakes? Austin Healey 36
C Wanted 3000 Front Disc Brakes Austin Healey Classifieds 4
C For Sale BN1 Front Drum Brakes assemblies and hubs for sale Austin Healey Classifieds 0
P Front drum brakes - fluid lines Austin Healey 12
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
C Value of BN1 Original Front Drum Brakes? Austin Healey 4
BN6_2197 Disassembling BN6 Front Brakes Austin Healey 14
trrdster2000 Post-War Other Front brakes on the Roadster Triumph 5
R BJ8 Front Brakes drag some Austin Healey 9
T TR2/3/3A TR3A front brakes Triumph 2
mgedit TR2/3/3A Front Drum Brakes 56 TR3 Triumph 2
D TR6 1976 TR6 Front Brakes & Shocks Triumph 3
M Stuck front brakes? Spridgets 8
M Front brakes are sticking Spridgets 33
C Bugeye Disc Front Brakes FORUM Navigation Questions 0
C Bugeye Disc Front Brakes Spridgets 4
coj 1960 Healey 3000 front and rear brakes Austin Healey 2
bighealeysource front disc brakes conversion for 100-4 Austin Healey 21
O TR2/3/3A 1960 TR3 Front Brakes Triumph 2
Stewart Dragging front brakes MG 7
B front disc brakes- 66 sprite Spridgets 8
RickB Front brakes seizing - what's with that? Spridgets 23
M Slight bind in front brakes Spridgets 7
R Front Brakes... Spridgets 7
sparkydave Dragging front brakes Spridgets 4
T Check list to convert to front disc brakes Spridgets 9
T Front disc brakes make a big difference? Spridgets 5
T Time to redo all my brakes and front suspension... Triumph 14
S TR2/3/3A tr3 front brakes hoses Triumph 9
drooartz Installing front suspension/brakes - review Spridgets 1
zschicago my first Healey and questions about front brakes Austin Healey 10
M Difference between MK IX and XK 150 Front Brakes? Jaguar 6
Brosky Front Suspension & Brakes -Done Triumph 5
N TR6 Clip wires on front brakes for TR6 Triumph 9
eejay56 BMW 320i front brakes locked up Other Cars 8
1 front brakes Spridgets 3
19_again leak front brakes MG 6
M front brakes Spridgets 12
M front brakes Austin Healey 3
jmwuva05 Front drum brakes. Spridgets 2
ncbugeye Front wheels won't spin, dsic brakes binding? Spridgets 13
zimmy front disk brakes Spridgets 9
T TR4/4A Early TR4 - Front Brakes Triumph 3
zimmy front brakes and calipers Spridgets 3
R TR6 TR6 front brakes Jack Drew Triumph 13
