Front disc brakes make a big difference?
tdskip
I have a front disc set up for the Bugeye, and since at some point she'll have the 1275 in her I'm not too concerned about originality. Anyone done the conversion and does it make a big difference?
Thanks!
I've done the conversion, but I never drove my car with the front drums. I've driven others with drums in the front, and I like the feel of mine better. The discs seem to catch quicker than the drums and require a little less pedal effort.
drooartz
I drove mine for a year on the drums, and never felt they were inadequate. That said, I'm im the process of finishing the disc swap right now. Seemed like the thing to do, since I was going to a 1275 as well.
texas_bugeye
drums fffade away disk brakes are there always. hmm theres a song in there some where... ta tata ta talkin bout my generation.
The disk may not have stompin and lockim down like some think but after a couple stops with the drums they do fade quite a bit coming down from say 50 -60 MPH and since your going with more power common sense says get more stopping power.
Billm
The disks stay in adjustment virtually forever (until you need to change pads) I found that I had to adjust the front drums too often to be happy with them.
The disks had significantly more stopping power and gave me a better level of confidence (is that an oxymoron with LBC's?).
Bill
bugimike
I have driven mine with both and definitely like the feel of the discs much better, and when it comes to service, I would much rather replace pads than shoes!!! :wink:
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
C Wanted 3000 Front Disc Brakes Austin Healey Classifieds 4
C Bugeye Disc Front Brakes FORUM Navigation Questions 0
C Bugeye Disc Front Brakes Spridgets 4
bighealeysource front disc brakes conversion for 100-4 Austin Healey 21
B front disc brakes- 66 sprite Spridgets 8
T Check list to convert to front disc brakes Spridgets 9
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
I Bug eye front disc brake conversion. Spridgets 5
L Denis Welch Front Disc Conversion Kit 100/6 Austin Healey 6
KVH TR4/4A Front Wire Wheel Hubs Differ from Disc Hubs?? Triumph 5
K TR2/3/3A Front disc brake squeal.... Triumph 4
croz TR2/3/3A Moss Replacement front disc pads Triumph 3
R BJ7 Front Brake disc hitting Austin Healey 12
maxwedge5281 front disc brake hubs for steel wheels Austin Healey 24
steveg Front Toyota disc conversion now complete - photo essay Austin Healey 0
pkmh Dismantling BJ8 Front Hub From Caliper Disc Austin Healey 20
R TR4/4A Disc wheel studs front and rear TR4a irs Triumph 4
O Front disc's from a 63 Midget Spridgets 0
Trevor Jessie Front brake line locating brackets [disc]. Spridgets 6
M BN4 prob with disc brake conversion[front] Austin Healey 2
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 3
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
