front brakes
mixbugeye
Member
hi all
i own a mk1 sprite
i am hoping to convert the front drums to disc brakes
have been told two different stories on parts required as i want this project to be done right first time but i dont want to buy parts i dont need
them main conflict is wether i need new stub axles and king pins as been told yes and no from two different suppliers and will the new king pins fit to old suspension bit confused as the dollar difference is a bit
any help would be appreciated
thanks
mick
Bugeye58
Mick, firstly, let me welcome you to the Forum. The Spridget group is quite active, and has a bunch of very knowledgeable folks.
The kingpins, stub axles and hubs are indeed different between the drum / disc brake cars. The ideal solution would be to find a suitable donor vehicle and swap everything over to the Frogeye. A '63 to '67 would be ideal, as you would retain the tandem master cylinder in the correct 3/4" bore size for the discs. Although some say they have done the conversion successfully using the original master cylinder, I have no personal experience with this approach.
If the donor car is difficult to find in Oz, another option may be to buy the required components here in the States, and have them shipped over. I recently bought kingpins, axles, hubs and calipers to convert one of mine for $250.00 (USD).
Hope this has helped, and keep us informed. I know there are several people here who have done the conversion other than myself.
Jeff
bugimike
I also have made the conversion (retaining the original MC) and would say that Jeff has pretty much covered the bases for you. I agree with him that the best way is to find a "donor" car of the right year and switch out the whole lot, A arms, spindles, kingpins etc. Makes the job just so much easier! /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
PS welcome to the best LBC forum on the planet!! /bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif
jlaird
Welcome indeed.
healeyboz
Welcome! Make sure to keep your old parts until the transplant is completed. You will need to use the original steering arms that connect to the tie rod ends. The originals are tapered.
John Moore
I eventually, want to do this. In addtion to the kingpins one also needs the "A" arms from the doner?
Later model A-arms have reinforcing plates on the underside. Not required, but a good idea if you are going to be using a sway(roll) bar.
John Moore
Thanks Trevor,
Not too far from me is a Brit Car shop where the guy has a bunch of used parts. He said he had a bunch of spridget suspension stuff laying about. I want to take a look.
What's needed to change the rear drums to a later model brake piston?
Bugeye58
John, you'll need the backing plates, complete with wheel cylinders and adjusters, and the later model emergency brake linkage. Prepare to make new rear lines, and while you're there, change the rear hose as well.
Jeff
M
mixbugeye
Member
thanks guys
jeff
your advise is extremly helpful and throws answer another question about master cylinder was told orig would work no prob
and nobody mentioned replacing the arms as well more dollars
a doner i think is a top idea
but your suggestion of parts from us is much cheaper option than ive found in australia looking at $2500 from suppliers
plus m/c
which supplier would you recomend and their website would be apreciated
thanks again to all
mick
Bugeye58
Mick, the steup I got for $250 was used, and didn't include the master cylinder. I found it on eBay.
You don't have to buy new steering arms, you use the ones you have now. The later production cars went to a different size tie rod end that used a smaller taper. The Frogeye arms will interchange perfectly, so you can use your existing setup.
How does the availability of a donor car look down there?
$2500.00 here will get you a daily driver!
Jeff
M
mixbugeye
Member
now i know what i need im started to have a look around for a mk2 or 3 or a midget and see what dollars there pulling for a wreck etc
unfortanitly $2500 wont buy a road worthy spirte in australia closer to 10g for a fairly good one
going to have a look on ebay international and see no parts avaiable at the moment in oz
thanx again jeff
mick
kcbugeye1275
Mick, welcome to the Forum. You will be glad when you have the disc brakes installed. Don't forget to buy new flexible brake lines. Stainless steel are not to much more expensive and are better.
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
K TR2/3/3A Sticking front brakes? Triumph 9
K TR2/3/3A The flexing front spindle and no brakes syndrome? Triumph 5
John_Mc TR6 Front brakes won't release Triumph 20
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
C 100-6 front drum brakes? Austin Healey 36
C Wanted 3000 Front Disc Brakes Austin Healey Classifieds 4
C For Sale BN1 Front Drum Brakes assemblies and hubs for sale Austin Healey Classifieds 0
P Front drum brakes - fluid lines Austin Healey 12
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
C Value of BN1 Original Front Drum Brakes? Austin Healey 4
BN6_2197 Disassembling BN6 Front Brakes Austin Healey 14
trrdster2000 Post-War Other Front brakes on the Roadster Triumph 5
R BJ8 Front Brakes drag some Austin Healey 9
T TR2/3/3A TR3A front brakes Triumph 2
mgedit TR2/3/3A Front Drum Brakes 56 TR3 Triumph 2
D TR6 1976 TR6 Front Brakes & Shocks Triumph 3
M Stuck front brakes? Spridgets 8
M Front brakes are sticking Spridgets 33
C Bugeye Disc Front Brakes FORUM Navigation Questions 0
C Bugeye Disc Front Brakes Spridgets 4
coj 1960 Healey 3000 front and rear brakes Austin Healey 2
bighealeysource front disc brakes conversion for 100-4 Austin Healey 21
O TR2/3/3A 1960 TR3 Front Brakes Triumph 2
Stewart Dragging front brakes MG 7
B front disc brakes- 66 sprite Spridgets 8
RickB Front brakes seizing - what's with that? Spridgets 23
M Slight bind in front brakes Spridgets 7
R Front Brakes... Spridgets 7
sparkydave Dragging front brakes Spridgets 4
T Check list to convert to front disc brakes Spridgets 9
T Front disc brakes make a big difference? Spridgets 5
T Time to redo all my brakes and front suspension... Triumph 14
S TR2/3/3A tr3 front brakes hoses Triumph 9
drooartz Installing front suspension/brakes - review Spridgets 1
zschicago my first Healey and questions about front brakes Austin Healey 10
v8mgbal front brakes Spridgets 9
M Difference between MK IX and XK 150 Front Brakes? Jaguar 6
Brosky Front Suspension & Brakes -Done Triumph 5
N TR6 Clip wires on front brakes for TR6 Triumph 9
eejay56 BMW 320i front brakes locked up Other Cars 8
1 front brakes Spridgets 3
19_again leak front brakes MG 6
M front brakes Austin Healey 3
jmwuva05 Front drum brakes. Spridgets 2
ncbugeye Front wheels won't spin, dsic brakes binding? Spridgets 13
zimmy front disk brakes Spridgets 9
T TR4/4A Early TR4 - Front Brakes Triumph 3
zimmy front brakes and calipers Spridgets 3
R TR6 TR6 front brakes Jack Drew Triumph 13
