Time to redo all my brakes and front suspension...
TR6BILL
My brakes are starting to, well, not brake very well. Everything was new about 8 years ago...hubs, calipers, etc. But I think I need to take it all down again and start over. The rear suspension is completely redone but all the brakes need to come down. Might as well change the front bushes, the Konis are still good as well as the springs. Just repaint and rebush. New pads in the front, turn the disks, check the trunnion. New rack is still good. Rear, new parts. Never ends. But it is fun. Too hot to drive anyway.
Has anyone ever Jet Hot coated the front suspension? Might look good.
DNK
Looks similar to powder coating which I did. Will work, no problem
Brosky
Probably more expensive than powder coating though.
Bill, did you ever install the larger spindles? That might be a good upgrade for your spirited driving.
tdskip
8 years on a set of bushings with a lot/sprited driving doesn't sound soooo bad Bill. What did you put in 8 years ago?
T
TR6BILL
OE rubber. Want to upgrade to something better. What is best now?
The larger spindle sounds like a good idea.
tdskip
Wow - 8 years on rubber bushings is longer than I would have expected. I think you got your money's worth out of those.
Poly bushings seems to be the near unanimous way to go - let the debate begin on where to source them.
I ordered mine with BP Northwest and they where good to work with and the bushings seemed to be of high quality.
DNK
Agree!
He didn't ask about that, just if had been done :devilgrin:
BobbyD
Brosky said:
....Bill, did you ever install the larger spindles? That might be a good upgrade for your spirited driving.
I second that suggestion.... Uncle Jack's upgraded stub axles are a worthwhile purchase. Did it a few years ago. Hey Paul....did you ever install them?
Brosky
Yes I did Bob, when I did the new suspension two years ago. I used the TRF upgraded kit, not UJ's but I think they are the same design.
Brosky
Re: Time to redo all my brakes and front suspensio
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Wow - 8 years on rubber bushings is longer than I would have expected. I think you got your money's worth out of those.[/QUOTE]
Tom,
I went 33 years on my originals and they were not too bad when I took them out. I went with the rubber again, which may or may not have been a mistake. Time will tell, as the rubber made today (in China) may or may not be as good as the originals.
tdskip
Maybe it is a climate difference then, but combination of the heat and how dry it is out here just trashes rubbers bushings in no time flat.
(maybe the SMOG as well...)
T
TR6BILL
My buddy has a media blasting box, a really large one, and I will take all the parts to have them cleaned up. Will decide which finish is best. Jet Hot would be pretty.
poolboy
TR6BILL said:
Too hot to drive
You got that right, bubba ! Like putting a hair dryer in front of your face.
I'm waiting on some RG rear springs to try out, gives me an excuse to stay home.
tdskip
poolboy said:
TR6BILL said:
Too hot to drive
Want some carbs to rebuild while you are waiting on the springs? Ha!
poolboy
Might as well,..but no micro polishing. At the most, I'd what you did to the covers. :cooler:
wangdango BJ8 console redo? Austin Healey 6
wangdango BJ8 front seat redo? Austin Healey 8
wangdango BJ8 dash top redo? Austin Healey 1
AEW Early master cylinder redo Triumph 0
wangdango BJ8 door hinge pillar plate redo Austin Healey 7
H Bugeye Sprite Side Curtains redo Spridgets 8
fad64b TR2/3/3A TR3 seat redo Triumph 17
SCguy TR4/4A TR4 Interior redo??? Triumph 7
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
I MGB Sticky Rotors/Brakes MG 5
KVH General Tech Rear Brakes and Solid Axle Triumph 2
R Bugeye drum brakes Spridgets 7
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
J Brakes Not Releasing Austin Healey 9
prb51 100-6 Drum Brakes Austin Healey 9
bighealeysource Drum Brakes Assembly Austin Healey 6
A Drum Brakes Again Austin Healey 18
NutmegCT Morris Minor brakes! Other British Cars 9
BritBite XKE BRAKES Jaguar 1
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
algot1901 Brakes for Anglia / Prefect Other British Cars 2
M TR6 76 TR6 Brakes too tight Triumph 10
fundytides Bleeding Lockheed Brakes on 1951 Vanguard Other British Cars 11
K TR2/3/3A Sticking front brakes? Triumph 9
B MGA After-market brakes MG 5
5 TR2/3/3A Seized rear brakes Triumph 9
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
Jeepster Rear Brakes Adjustment Austin Healey 6
C TR2/3/3A bleeding brakes Triumph 11
L TR6 Rear Brakes Shoe Repair and Install Triumph 2
R TR2/3/3A Girling Rear Brakes Triumph 9
A TR6 '74 TR6 no brakes Triumph 14
FlyingCat Spitfire Bleedin' Brakes Triumph 6
R TR2/3/3A Rear Brakes Triumph 9
K TR2/3/3A The flexing front spindle and no brakes syndrome? Triumph 5
HalLucy Post-War Other 1949 2000 Triumph Roadster brakes Triumph 17
S TR2/3/3A Now the bad news. BRAKES Triumph 7
M TR6 Rear brakes Triumph 2
John_Mc TR6 Front brakes won't release Triumph 20
A TR2/3/3A Brakes, exhaust and trunk floor Triumph 2
P Brakes lock up when rolling forward Austin Healey 4
P Honda weak brakes Other Cars 10
dklawson Spitfire Bleeding Herald Brakes [similar to Spit] Triumph 9
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
C 100-6 front drum brakes? Austin Healey 36
D TR5/TR250 Squealing brakes Triumph 4
R General Tech Loss of brakes Triumph 11
R 100 Brakes Austin Healey 3
Trevor Jessie When was the last time you bled your brakes? Spridgets 4
R 3/4" Bore or 7/8" Bore Master Cylinder For Disc Brakes? Spridgets 4
