Drum Brakes Assembly
bighealeysource
Bronze
Hey all,
Well, seem to be having stupid issues right now with driver's side rear brakes. I pulled the hub and then brake drum off, which did not come off easily. Had the adjuster all the way closed and shall we say, used a lead hammer to help it off. Don't get what I am doing wrong as all was okay - had a squeaking noise when moving slowly - but otherwise braking okay.
Now I can't get the bloody thing back on with same adjuster closed down. Or if I get it on, barely able to turn the brake drum. Brake shoes have been on so some wear but still relatively new. Read the manual and have done this several times before but think I have a brain block right now. Believe I read something at one time about making sure the brake shoes were oriented the correct way but cannot find that.
Any ideas on what could be wrong?
Thanks
Mike
BobHaskell
Parking brake is off, right? The wheel cylinder sits in a slot in the backing plate. Does it move when you use/release the parking brake?
Legal Bill
Based on your original post, I’m assuming this drum went on and came off easily in the past. I’m also assuming you did not change any parts after you got the drum off. I’m also assuming you didn’t disassemble anything beyond removing the brake drum. If my assumptions are wrong, my advice could be wrong.
Check the wheel cylinder to make sure the piston is withdrawing into its cylinder. Sometimes they get hung up and won’t return completely. Also make sure the wheel cylinder is expanding and retracting when the adjuster screw is turned. Also check to make sure all the parts are free to move as intended. Sometimes the wheel cylinder and brake shoes hang up due to rust and road debris. You may need to disassemble, clean and reassemble all the brake parts and clean the brake backing plate. Make sure the shoes are sitting tight against the backing plate and yes, make sure the brake shoe orientation is correct. If you can’t find what you need in the manual, remove the drum on the other side and take a look. Finally, check the springs to see if they are tight when assembled and are able to return the wheel cylinder piston into its cylinder.
bighealeysource
bighealeysource
Bronze
Hey all,
Thanks for all the suggestions. Going to see what I have re the brake cylinder, parking brake, etc and like Legal Bill's idea of taking the opposite side brake drum off to see what I have there as no issues with that side. Assumptions are correct, nothing has been changed.
nevets
Was the hub removed in order to do brake work or to do work on the hub, just wondering? Was it difficult to remove the drum because there was interference with the brake shoes? Is the parking brake linkage in good order?
bighealeysource
bighealeysource
Bronze
Gentlemen,
Well, as far as I can determine, issue was one brake shoe was not tight against the backing plate which I assume threw everything off- thanks Legal Bill for mentioning that. Everything else matched the right side which does have the ability to adjust the brake linings with the brake adjuster. Driver's side adjuster is all the way closed and drum/wheel does turn okay. I'm using Moss brake shoes and wonder if the thickness might be
off a bit. Didn't measure as all back together now. On hard braking does pull to the right so guessing I need to adjust the right side a tad so they brake evenly. Thanks for your help as sometimes you can stare at the problem for hours and not come up with a solution.
Happy Thanksgiving,
Mike
R Bugeye drum brakes Spridgets 7
prb51 100-6 Drum Brakes Austin Healey 9
A Drum Brakes Again Austin Healey 18
C 100-6 front drum brakes? Austin Healey 36
S Servicing BJ8 drum brakes Austin Healey 3
C For Sale BN1 Front Drum Brakes assemblies and hubs for sale Austin Healey Classifieds 0
Popeye TR4/4A Rear brakes - spring plates and drum alignment Triumph 3
P Front drum brakes - fluid lines Austin Healey 12
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
C Value of BN1 Original Front Drum Brakes? Austin Healey 4
M Ever seen this ? - early wire hubs for drum brakes Spridgets 10
mgedit TR2/3/3A Rear Drum Brakes 56 TR3 Triumph 2
mgedit TR2/3/3A Front Drum Brakes 56 TR3 Triumph 2
healeyblue Drum brakes for 100-6 Austin Healey 10
D Early Bugeye Drum Brakes Spridgets 4
7 squealing [Humming] sound rear DRUM brakes Other Cars 3
M Squeky drum brakes Spridgets 6
M Dumb Dumb Question about Drum Brakes [pics] Triumph 10
P REAR DRUM BRAKES Spridgets 1
R Rear Drum Brakes on a BE Spridgets 5
Atrus Drum brakes - how much drag? Spridgets 5
Atrus Drum brakes too tight? Spridgets 7
jmwuva05 Front drum brakes. Spridgets 2
L how change drum brakes to disc? Austin Healey 6
HAN8L1965 Removing backing plate on rear drum brakes Spridgets 3
HAN8L1965 Removing backing plate -drum brakes Austin Healey 0
K Adjusting drum brakes MG 5
Z Adjusting Rear Drum Brakes 64' Sprite Spridgets 9
A Later drum backing plates - hub not clearing Spridgets 2
D Rear Brake Drum Nuts Austin Healey 15
Upland 69 Sprite drum brake adjuster Spridgets 7
D brake drum question Austin Healey 5
I Bugeye drum to disk brake conversion Spridgets 23
HealeyRick Proof of Concept - Drum Balancing Austin Healey 21
M Brake Drum Help - 60 Sprite Spridgets 88
W Bugeye With Squealing Drum Brake Spridgets 5
maxwedge5281 bn6 drum brake front hubs Austin Healey 3
warwick-steve Brake drum check and lubrication Austin Healey 9
NutmegCT T-Series TD brake drum removal MG 0
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
nevets stuck rear brake drum Austin Healey 18
Jim_Gruber A Victory to report over those bastard Rear Drum Circlips for Bugsy IV/Hub rubbing Spridgets 3
R BT7 Brake Drum Color Austin Healey 7
PatGalvin TR2/3/3A Drum Brake Question Triumph 3
A rear brake drum too tight after rebuild Austin Healey 3
D TR2/3/3A 1957 Girling adjuster on left rear drum frozen Triumph 8
Scotsman TR2/3/3A Drum break turning specifications Triumph 2
trotti Stuck drum - any ideas? Austin Healey 5
K TR2/3/3A Rear brake drum won't go on? Triumph 12
