TR2/3/3A Sticking front brakes?
karls59tr
Bronze
Driving my TR3 the other day on a bit of a long distance run and I got the distinct impression that the front brakes were partially on when they shouldn't be! Under what circumsatnces would this happen? The brake hoses were upgraded to the stainless ones years ago. Removed the restrictor valve this year. Apparently this valve was installed to keep the brake pads closer to the disc according to what I have read. (Those who have removed the restrictor said that it made little or no difference in actual braking.) Any thoughts on why the front brakes would tend to stay on?
Sarastro
There are lots of possible reasons; we'd just be guessing. Usually it is some corrosion in the caliper. I'm told that a plugged flex line can do it too, but I've never seen that, myself.
In a disk brake, the piston seal distorts when you brake, and then relaxes when you release the brake. That relaxation is what withdraws the piston. It doesn't take much to keep that from happening. A little rust or a little crud is plenty.
K
karls59tr
Bronze
Thanks I'll have to take a look to see if the pistons are sticking in the bore. I'm wondering if some type of light lubrication on the piston might might be beneficial or would that interfere with what the seal does?
bobhustead
How new are your pads? I have a belief, without empirical evidence, that new pads are sometimes too thick and drag when thoroughly warmed up.
Bob
Sarastro
The thing is, if they are sticking, you need to take them apart, remove the rust or dirt or whatever is doing it, and then put them together with new seals and, if necessary, pistons. When you do that, it's good to lubricate the piston lightly with brake fluid, but nothing else.
MK3HumberSceptre
Like Many have stated there are lots of possible reasons.1: Pads to tight in Caliper ( due to rust build up and or if the paint/coating is to thick)
2: Caliper Pistons not retracting due to ..hydraulic pressure not being fully released (due to brake hoses, internal or external proportional valve / piston, Brake Pedal adjustment i.e.: not enough free play between pedal push rod and master cylinder ( have seen misadjusted brake switched not allowing pedal to release properly, caliper piston sticking due to corrosion or piston seals over heated and hard or just old.
plus many other possibilities.
Questions are.... Is it both or just one front brake dragging or is it possible it's a rear brake issue !!! Not sure how easy it is for the issue to be duplicated, But if it can be, stop the vehicle and feel / measure to temp of each road wheel to determine if its on or more wheel are warmer that they should be, then maybe then it can be narrowed down to which Axle / wheel the issue is affecting.
K
karls59tr
Bronze
I'm thinking that I may have installed the spacers incorrectly at the caliper mounts on the right wheel causing the brake pad to constantly rub? Going to have a look tomorrow. I deactivated the proportioning valve some time ago and the brake hoses are the stainless type. Going to have a look at the caliper piston and seals as well (y)
Snowkilts
Rusty caliper pistons are common and will cause this. New stainless steel ones are available. Magically, my car doesn't pull any more when step on the brakes! :smile:
M Front brakes are sticking Spridgets 33
F Choke sticking Austin Healey 22
steveg "Sticking" the brake pedal Austin Healey 3
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
T TR2/3/3A Sticking Clutch Triumph 6
vickxxx TR2/3/3A Overdrive solenoid sticking Triumph 6
T throttle sticking? Austin Healey 4
T TR4/4A Overdrive piston is sticking Triumph 9
K TR2/3/3A Oil pressure gauge indicator needle sticking? Triumph 10
B Sticking Starter Pinion Austin Healey 6
M Sticking speedometer needle Triumph 2
J Oilcan spot on fender [IE: not flat, sticking out Triumph 2
J STICKING THROTTLE PLATES Jaguar 7
TR4nut H6 carbs -jets sticking Triumph 15
Kleykamp TR2/3/3A sticking clutch ??? TR3 Triumph 5
M Sticking M/C piston Triumph 7
Got_All_4 TR2/3/3A SU pistons sticking in TR3 Triumph 11
T TR2/3/3A TR3 Sticking Brakes - How come and what to do? Triumph 5
bcbennett TR6 Sticking TR6 throttle Triumph 28
TimK sticking rear brakes Austin Healey 8
R sticking speedometer Triumph 1
KVH TR4/4A Sticking Accelerator or SU Jets: TR4A Triumph 7
mountainman SU Choke sticking! Help Triumph 6
doughairfield Jet Assembly sticking Triumph 6
jtownhealey61 AH 3000 Overdrive - sticking engaged Austin Healey 4
R 1275 timing/ carb pistion sticking Spridgets 3
K Sticking Floats Triumph 12
healeyneil Sticking back brake BJ8 Austin Healey 0
M Bugeye clutch pedal sticking Spridgets 2
R TR2/3/3A TR3a- grose float valves sticking Triumph 6
B Sticking float valves Spridgets 12
Steve P. 1500 Midget; sticking choke Spridgets 6
NickMorgan Sticking horn push Triumph 8
A carburettor air valve sticking Triumph 3
George Zeck Choke is sticking ??? Spridgets 11
RickB Gas pedal sticking - maybe the cable? Spridgets 15
Morris Sticking Shock Spridgets 2
D Sticking Brakes Spridgets 22
X Throttle linkage sticking Spridgets 6
B Is my Thermostat Sticking? MG 9
R Clutch Sticking Problem Austin Healey 4
weewillie sticking butterfly Spridgets 8
TR6oldtimer TR6 TR6 door bottom sticking out Triumph 2
R_Lyle Steering Rack sticking Triumph 4
T Sticking throttle - any ideas? Triumph 8
T Likely cause of throttle sticking open Triumph 5
B Carb Problem - Something's sticking Austin Healey 43
jollyroger Transmission sticking in 1.st Spridgets 3
D Sticking Bonnet Spridgets 4
Webb Sledge TR6 Sticking TR6 Clutch Triumph 15
