SU Choke sticking! Help
mountainman
The front carb choke will not return all the way home once it is pulled out. I have disconnected all the linkage and even lifted the piston to make sure it was not sticking on the needle. These carbs have been completely rebuilt but have sat for about 6 months. You can shove it home with a little pressure. Could it be the sealing gland washer or conical washer is to tight?
Thanks
Greg
TR3driver
Great Pumpkin - R.I.P
Main thing is to remove the jet, and polish the outside surface until it is shiny. They used to be supplied that way, but many replacements are left dull, which both drags more on the seals and shortens their life.
I would also suggest replacing both the return spring outside, and the spring inside the jet that puts pressure on the seals. These aren't included in the rebuild kits, but are available separately from TRF (probably others as well). Some re-builders and/or DPOs cannot resist temptation, and stretch the inner spring in an attempt to stop the seals from leaking. That puts too much force on the seals, and causes the just to be too stiff. The return spring just gets tired, sometimes.
A very thin smear of silicone grease on the jet might help too, but of course don't let it block the holes.
doughairfield
:iagree:
I had the exact same problem with my TR4 carbs. Rebuilt, sat for a few months, front jet assembly sticks when I push the choke back in. I followed Randall's advice and disconnected the linkage and pulled the jet assembly all the way out. I spent some time polishing the jet assembly and put a thing layer of silicone grease on it. I found a little of silicone grease meant to lubricate brakes at the front counter of my local auto parts store, couldn't find any anywhere else.
Then I slid the jet back in, working it in and out feeling for any rough spots. Starts and runs like a champ now.
TR3driver
Platinum
Dow Corning used to have "Stopcock Grease" for laboratory glass stoppers, now I think its renamed "111" silicone grease or the like.
eschneider
some would argue that the nitrile o-ring seals prevent sticking better than the cork ones.
also - it seemed as if you were asking if this could be caused by over-tightening the large cork conical washer / big nut holding the jet assembly in place???? I would think that would NOT be a cause of the jet sticking.
Mkutz
I had the devil of a time with the rubber o-ring seals....ethanol fuels expanded the rubber causing substantial leaking...I'm sticking with 24 hour oil soaked cork seals
F Choke sticking Austin Healey 22
Steve P. 1500 Midget; sticking choke Spridgets 6
George Zeck Choke is sticking ??? Spridgets 11
B Sticking throttle and choke knob question Spridgets 9
Todd78d Bugeye choke linkage Spridgets 5
Todd78d Choke Linkage Photo Austin Healey 0
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
D BT7 Choke Assembly Austin Healey 18
P MGB Zenith water choke gasket needed MG 4
D Choke Cable Length Austin Healey 0
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
L MGB 1977 MGB will only run on full choke MG 53
SherpaPilot TR6 Choke Assembly Triumph 0
M Choke Linkage Austin Healey 3
D Carb Choke Cable Austin Healey 9
M TR6 1973 TR6 - broken choke cable Triumph 6
TomMull TR2/3/3A Which choke cable Triumph 12
sparkydave Zenith auto choke coming loose Spridgets 2
T TR6 TR6 Choke Cable Lubrication Triumph 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
K TR2/3/3A Couple of choke questions Triumph 1
K Choke cable replacement Austin Healey 1
D AH 300O MK1 Choke Knob Position Austin Healey 5
R Jensen-Healey Choke? Other British Cars 1
F TR2/3/3A Choke Cable Problem Triumph 29
N Enrichener [choke] wire Austin Healey 1
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
F TR2/3/3A Choke Triumph 1
edkap2002 TR6 72 tr6 choke cable Triumph 4
Patrick67BJ8 BJ8 Choke Cables Austin Healey 5
TRMark TR4/4A Choke Cable Routing Triumph 3
S TR2/3/3A choke operation from the factory !!!! Triumph 29
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
S TR4/4A aftermarket choke cable Triumph 3
sparkydave Zenith auto choke coming loose Spridgets 3
K TR4/4A Strombergs...wont idle unless choke pulled out? Triumph 7
UmmYeahOk GT6 I Give Up! Help A Millennial Out [Carb/Choke Related] Triumph 28
M TR2/3/3A Choke Cable Detent Device Triumph 11
Rob Glasgow Choke cable turnion Austin Healey 8
TomMull TR2/3/3A Choke on new to me TR3 Triumph 16
L Choke Mechanism 100/6 Austin Healey 26
trrdster2000 TR6 Double Choke Cable Repair Triumph 0
1 TR6 Tr6 needs choke to run good Triumph 11
rjc157 bn7 electronic choke Austin Healey 0
A 1960 BT7 choke location Austin Healey 8
