Deamaker 5
Hey guys, the choke assembly had a bracket that mounts to the one carburetors on a BT7 - dual carb - set up . Question is on the large trinnion that goes into that bracket - it has 2 pieces, 2 washers, and a nut - how does this trinnion clamp down on the choke cable coming through it?
I have tightened the nut on the trunnion, however, you can still pull the cable loose or the cable will move once u pull the choke out. Maybe I am looking at this too hard, but perhaps I don’t understand how this trunnion works. Thanks.
