TR4/4A aftermarket choke cable
shoopal
It measures 5 ft long. It seems like I need to hack off at least 2 ft. Anyone know a trick for cutting this cable? Also it came with a knob. I would like to use an original knob which I have. Is there a problem?
Al Shoop
TR3driver
Great Pumpkin - R.I.P
If it came with a knob, very likely the knob doesn't mount the same as the original. You might be able to make up an adapter, though. I have one of my TR3 knobs mounted to a piece of hex computer board standoff, with a tiny setscrew in place of the spring pin. If the aftermarket knob doesn't unscrew, you may have to break it off and thread the end of the shaft for the adapter.
Remove the inner cable, and if it is stranded, wrap a turn of masking tape tightly around it. Then cut it slowly with a Dremel and abrasive cutoff blade. The cable is hardened spring steel, so ordinary cutters cannot cut it cleanly (and will be damaged by the attempt). The same tool will also cut the outer housing cleanly. Dress any sharp edges before you put it back together.
S
shoopal
Hi Randall
It's always something. First of all you are right. The knobs don't match. The original has a large hex hole the aftermarket has a smaller round hole. Secondly, the aftermarket has a slightly larger outer diameter and does not fit into the carburetor receptacle. Lastly, it's way too long although thanks for the cutting tip. I do have a tool for cutting stainless braid, the housing is another matter.
With heating and a liberal dose of penetrating oil, I have managed to reclaim the old cable so that is what I will use. Sadly I have the new unused cable which I can't return. I bought it many years ago and I also cut up the bag it came in and I doubt that Moss will take it back. Anyway, thanks for being there.
Al Shoop
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
roscoe Aftermarket Seats with Headrests Austin Healey 9
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
Y MGB Aftermarket wheels MG 5
kodanja TR2/3/3A Rocker studs for aftermarket Rocker covers Triumph 4
kodanja TR2/3/3A Aftermarket Sun Visors? Triumph 12
K TR2/3/3A Aftermarket Distributor Points and Terminal Bush leads? Triumph 1
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
B For Sale Seat Mounting brackets for aftermarket seats Spridgets Classified 0
Z TR2/3/3A Windshield Aftermarket Triumph 22
S TR2/3/3A Stock air cleaners and aftermarket air cleaners. Triumph 7
B 100-4 Aftermarket Hardtops Austin Healey 7
H TR4/4A Original TR4a grill versus aftermarket Triumph 0
55modified Need suggestions for fastening aftermarket hardtop for BN1. Austin Healey 15
Csarneson Rear Springs - Aftermarket or buy an old used pair Austin Healey 10
W TR6 tr6 horn aftermarket Triumph 1
T TR6 TR6 aftermarket rear shocks Triumph 35
NutmegCT Aftermarket a/c? Restoration & Tools 15
T TR2/3/3A Question on TR3A aftermarket side curtains Triumph 8
T TR2/3/3A Aftermarket brake master cylinder 1961 TR 3A Triumph 11
S TR2/3/3A aftermarket trunnions? Triumph 6
R Installing an aftermarket brake servo kit Austin Healey 6
F Thoughts on aftermarket air cleaners? Austin Healey 12
J aftermarket sheetmetal Spridgets 2
66healey Aftermarket brake booster pictures Austin Healey 7
Gray_Cat Bugeye Aftermarket Steering Wheels Spridgets 15
V TR6 Top, aftermarket plastic/fiberglass for TR6? Triumph 6
Branson Aftermarket wiring harness + original sprite wire Spridgets 5
R Red, white and tan covert tops aftermarket 60's? Triumph 11
B Spitfire Aftermarket synchros 1500 Spit single rail Triumph 2
J TR2/3/3A Aftermarket starter for TR3 question Triumph 8
RJS Aftermarket Cooling Fans Triumph 3
W TR6 TR6 aftermarket headers Triumph 26
newmexTR3 TR2/3/3A Aftermarket headlight relay mounting options TR2-4 Triumph 5
S MGB Aftermarket starter for 66 mgb MG 9
King_of_England aftermarket gear reduction starter failure Triumph 10
M TR6 ??TR6 steering wheel NOS or Aftermarket on ebay?? Triumph 7
Don_R Aftermarket Steering Wheel Triumph 7
newmexTR3 TR2/3/3A TR3 Aftermarket Door Seals that work? Triumph 11
R TR6 TR6 Aftermarket Seatbelts Triumph 4
Editor_Reid Rare 100 Aftermarket Accessory Austin Healey 7
rustbucket T-Series Original vs. Aftermarket Cutch MC & Slave MG 4
71TR6 TR6 Aftermarket TR6 Steel Wheel Triumph 3
R TR2/3/3A TR3 Hardtop OEM or Aftermarket Triumph 21
K TR6 Custom Hardtops - aftermarket top TR6 Triumph 11
AUSMHLY Survey - stock, hybrid, aftermarket steering wheel Austin Healey 37
Steve P. 5" aftermarket rims, what tire size needed??? Spridgets 3
v8mgbal aftermarket steering wheels Spridgets 19
B Aftermarket Radio Install Spridgets 28
