Aftermarket brake booster pictures
66healey
Member
Does anyone have any pictures of a installed aftermarket brake booster? I cant for the life of me figure out which way I'm supposed to mount this thing!
Not to say that this is the right (or only) way, it just happened to be what looked right for me... at that time :wink:
https://www.spcarsplus.com/gallery3/index.php/reMKIII/work_from_3-25-11_onwards?page=6
richberman
66:
Look at my build here.
Brake booster
There are more pictures. I used a Lockhead aftermarket Servo (AHSpares supplied) and used their bracket for this booster.
I just put one on the BJ8 like the one Randy has. I couldn't figure out how to use the one that was supplied so I build new ones that mount with the same original places. I did have to make the mount drop the the booster down some to have it look more original. Used the supplied strap to keep vibration down.
Marv
66healey said:
Thanks, I think I will be able to figure it out. Randy, is your mounting bracket attached to the frame rail?
Yes, as can be seen, the toeboard was (very) poorly repaired__<span style="font-style: italic">by others</span> before me, and I wouldn't have trusted it to support the floormat, let alone the brake booster.
Please note that isn't my car, just one I was doing some work on.
Jeepster
I tried to fit an after market unit on my BJ8 over christmas. I bought a bracket from AH spares that allows you to fit the unit at 90 degrees and mounts on the original servo brackets. After much swearing and the realisation that I would never get access to anything after it was fitted, I sent it back and got the original Girling unit reconditioned. Best decision I ever made.
old BJ8 driver
Hello - first time on this sight and I am looking for help in configuring brkts for the aftermarket Lockheed servo unit. The two brkts that I got don't make any sense at all and will not fit
inside the inner fender where the old Girling unit used to sit. If there are pictures of how you mounted this unit that you would be willing to share, I'd sure appreciate it.
T TR2/3/3A Aftermarket brake master cylinder 1961 TR 3A Triumph 11
R Installing an aftermarket brake servo kit Austin Healey 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
roscoe Aftermarket Seats with Headrests Austin Healey 9
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
Y MGB Aftermarket wheels MG 5
kodanja TR2/3/3A Rocker studs for aftermarket Rocker covers Triumph 4
kodanja TR2/3/3A Aftermarket Sun Visors? Triumph 12
K TR2/3/3A Aftermarket Distributor Points and Terminal Bush leads? Triumph 1
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
B For Sale Seat Mounting brackets for aftermarket seats Spridgets Classified 0
Z TR2/3/3A Windshield Aftermarket Triumph 22
S TR2/3/3A Stock air cleaners and aftermarket air cleaners. Triumph 7
B 100-4 Aftermarket Hardtops Austin Healey 7
H TR4/4A Original TR4a grill versus aftermarket Triumph 0
55modified Need suggestions for fastening aftermarket hardtop for BN1. Austin Healey 15
S TR4/4A aftermarket choke cable Triumph 3
Csarneson Rear Springs - Aftermarket or buy an old used pair Austin Healey 10
W TR6 tr6 horn aftermarket Triumph 1
T TR6 TR6 aftermarket rear shocks Triumph 35
NutmegCT Aftermarket a/c? Restoration & Tools 15
T TR2/3/3A Question on TR3A aftermarket side curtains Triumph 8
S TR2/3/3A aftermarket trunnions? Triumph 6
F Thoughts on aftermarket air cleaners? Austin Healey 12
J aftermarket sheetmetal Spridgets 2
Gray_Cat Bugeye Aftermarket Steering Wheels Spridgets 15
V TR6 Top, aftermarket plastic/fiberglass for TR6? Triumph 6
Branson Aftermarket wiring harness + original sprite wire Spridgets 5
R Red, white and tan covert tops aftermarket 60's? Triumph 11
B Spitfire Aftermarket synchros 1500 Spit single rail Triumph 2
J TR2/3/3A Aftermarket starter for TR3 question Triumph 8
RJS Aftermarket Cooling Fans Triumph 3
W TR6 TR6 aftermarket headers Triumph 26
newmexTR3 TR2/3/3A Aftermarket headlight relay mounting options TR2-4 Triumph 5
S MGB Aftermarket starter for 66 mgb MG 9
King_of_England aftermarket gear reduction starter failure Triumph 10
M TR6 ??TR6 steering wheel NOS or Aftermarket on ebay?? Triumph 7
Don_R Aftermarket Steering Wheel Triumph 7
newmexTR3 TR2/3/3A TR3 Aftermarket Door Seals that work? Triumph 11
R TR6 TR6 Aftermarket Seatbelts Triumph 4
Editor_Reid Rare 100 Aftermarket Accessory Austin Healey 7
rustbucket T-Series Original vs. Aftermarket Cutch MC & Slave MG 4
71TR6 TR6 Aftermarket TR6 Steel Wheel Triumph 3
R TR2/3/3A TR3 Hardtop OEM or Aftermarket Triumph 21
K TR6 Custom Hardtops - aftermarket top TR6 Triumph 11
AUSMHLY Survey - stock, hybrid, aftermarket steering wheel Austin Healey 37
Steve P. 5" aftermarket rims, what tire size needed??? Spridgets 3
v8mgbal aftermarket steering wheels Spridgets 19
B Aftermarket Radio Install Spridgets 28
