TR2/3/3A Aftermarket Distributor Points and Terminal Bush leads?
karls59tr
Bronze
Here are some pictures of the new aftermarket distributor parts I received. I ordered Lucas but got these instead. 100_2093.jpg You can see the difference of the end pieces.100_2095.jpg Bush terminal end pieces. If you look at the end of the "old terminal" lead you can see where the wire insulation failed.
The problem is when everything is installed the end pieces( what are they called?) are touching the plate hold down screw???? Would that not ground out the points? Something is not right? How much space is there normally on a good set of points between the end terminals and the hold down screw?
Also I've managed to drop the the plate screw lock washer down into the distributor internals %$&^*@ Any advice on getting that out. Going to have to pull it I suppose.
Geo Hahn
...The problem is when everything is installed the end pieces( what are they called?) are touching the plate hold down screw???? Would that not ground out the points? Something is not right? How much space is there normally on a good set of points between the end terminals and the hold down screw?
Not exactly sure what you're describing but maybe this helps...
...Also I've managed to drop the the plate screw lock washer down into the distributor internals %$&^*@ Any advice on getting that out. Going to have to pull it I suppose.
A magnet or even a magnetized thin screwdriver might be able to fish it out. The distributor body is not ferrous so there is a good chance that might work though you may need to remove the base plate to get at it. Otherwise, you can just pull the distributor and shake it out.
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
roscoe Aftermarket Seats with Headrests Austin Healey 9
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
Y MGB Aftermarket wheels MG 5
kodanja TR2/3/3A Rocker studs for aftermarket Rocker covers Triumph 4
kodanja TR2/3/3A Aftermarket Sun Visors? Triumph 12
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
B For Sale Seat Mounting brackets for aftermarket seats Spridgets Classified 0
Z TR2/3/3A Windshield Aftermarket Triumph 22
S TR2/3/3A Stock air cleaners and aftermarket air cleaners. Triumph 7
B 100-4 Aftermarket Hardtops Austin Healey 7
H TR4/4A Original TR4a grill versus aftermarket Triumph 0
55modified Need suggestions for fastening aftermarket hardtop for BN1. Austin Healey 15
S TR4/4A aftermarket choke cable Triumph 3
Csarneson Rear Springs - Aftermarket or buy an old used pair Austin Healey 10
W TR6 tr6 horn aftermarket Triumph 1
T TR6 TR6 aftermarket rear shocks Triumph 35
NutmegCT Aftermarket a/c? Restoration & Tools 15
T TR2/3/3A Question on TR3A aftermarket side curtains Triumph 8
T TR2/3/3A Aftermarket brake master cylinder 1961 TR 3A Triumph 11
S TR2/3/3A aftermarket trunnions? Triumph 6
R Installing an aftermarket brake servo kit Austin Healey 6
F Thoughts on aftermarket air cleaners? Austin Healey 12
J aftermarket sheetmetal Spridgets 2
66healey Aftermarket brake booster pictures Austin Healey 7
Gray_Cat Bugeye Aftermarket Steering Wheels Spridgets 15
V TR6 Top, aftermarket plastic/fiberglass for TR6? Triumph 6
Branson Aftermarket wiring harness + original sprite wire Spridgets 5
R Red, white and tan covert tops aftermarket 60's? Triumph 11
B Spitfire Aftermarket synchros 1500 Spit single rail Triumph 2
J TR2/3/3A Aftermarket starter for TR3 question Triumph 8
RJS Aftermarket Cooling Fans Triumph 3
W TR6 TR6 aftermarket headers Triumph 26
newmexTR3 TR2/3/3A Aftermarket headlight relay mounting options TR2-4 Triumph 5
S MGB Aftermarket starter for 66 mgb MG 9
King_of_England aftermarket gear reduction starter failure Triumph 10
M TR6 ??TR6 steering wheel NOS or Aftermarket on ebay?? Triumph 7
Don_R Aftermarket Steering Wheel Triumph 7
newmexTR3 TR2/3/3A TR3 Aftermarket Door Seals that work? Triumph 11
R TR6 TR6 Aftermarket Seatbelts Triumph 4
Editor_Reid Rare 100 Aftermarket Accessory Austin Healey 7
rustbucket T-Series Original vs. Aftermarket Cutch MC & Slave MG 4
71TR6 TR6 Aftermarket TR6 Steel Wheel Triumph 3
R TR2/3/3A TR3 Hardtop OEM or Aftermarket Triumph 21
K TR6 Custom Hardtops - aftermarket top TR6 Triumph 11
AUSMHLY Survey - stock, hybrid, aftermarket steering wheel Austin Healey 37
Steve P. 5" aftermarket rims, what tire size needed??? Spridgets 3
v8mgbal aftermarket steering wheels Spridgets 19
B Aftermarket Radio Install Spridgets 28
