Choke Linkage Photo
Todd78d
Todd78d
Member
Could someone provide a picture of the correct choke linkage on a Sprint Bugeye?
I have a 1960 that I just purchased and the linkage has wire connecting it together.
Thank you.
Todd78d Bugeye choke linkage Spridgets 5
M Choke Linkage Austin Healey 3
S TR4/4A choke linkage Triumph 2
B Front carb choke linkage pin Triumph 5
K TR2/3/3A TR3 SU choke linkage horizontal bar that connects Triumph 2
M WTB: Tri Carb Choke Linkage Parts Austin Healey 8
M Choke linkage nuts Triumph 9
J TR2/3/3A tr3 choke linkage issues Triumph 7
doughairfield Pic of the choke linkage Triumph 0
S HS2 SU dual carb throttle/choke linkage Spridgets 10
DenverMGB Weber Carb 32/36 DGV - Choke Linkage? MG 18
NutmegCT TR2/3/3A TR3 choke linkage Triumph 12
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
D BT7 Choke Assembly Austin Healey 18
P MGB Zenith water choke gasket needed MG 4
D Choke Cable Length Austin Healey 0
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
L MGB 1977 MGB will only run on full choke MG 53
SherpaPilot TR6 Choke Assembly Triumph 0
D Carb Choke Cable Austin Healey 9
M TR6 1973 TR6 - broken choke cable Triumph 6
TomMull TR2/3/3A Which choke cable Triumph 12
sparkydave Zenith auto choke coming loose Spridgets 2
T TR6 TR6 Choke Cable Lubrication Triumph 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
K TR2/3/3A Couple of choke questions Triumph 1
K Choke cable replacement Austin Healey 1
D AH 300O MK1 Choke Knob Position Austin Healey 5
R Jensen-Healey Choke? Other British Cars 1
F TR2/3/3A Choke Cable Problem Triumph 29
F Choke sticking Austin Healey 22
N Enrichener [choke] wire Austin Healey 1
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
F TR2/3/3A Choke Triumph 1
edkap2002 TR6 72 tr6 choke cable Triumph 4
Patrick67BJ8 BJ8 Choke Cables Austin Healey 5
TRMark TR4/4A Choke Cable Routing Triumph 3
S TR2/3/3A choke operation from the factory !!!! Triumph 29
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
S TR4/4A aftermarket choke cable Triumph 3
sparkydave Zenith auto choke coming loose Spridgets 3
K TR4/4A Strombergs...wont idle unless choke pulled out? Triumph 7
UmmYeahOk GT6 I Give Up! Help A Millennial Out [Carb/Choke Related] Triumph 28
M TR2/3/3A Choke Cable Detent Device Triumph 11
Rob Glasgow Choke cable turnion Austin Healey 8
