TR4/4A choke linkage
shoopal
Hi all
When my body shop lifted the body off the frame,they removed the carbs (SU HS6) as per the manual. Unfortunately the manual didn't tell them to save the linkages. I have 2 spare throttle linkages (no return springs) from donor cars but no choke linkage.
I appears that the part of the throttle linkage that links the throttle plates would fit the choke side (cutting off the tab to the bell crank)
Anyone have experience in this? or a spare choke linkage that you will sell or trade or donate (just kidding)
Pictures of the springs location would also be nice.
Thanks
Al Shoop
TR3driver
Great Pumpkin - R.I.P
S
shoopal
Hi
Great pictures. It seems like the two linkage rods are about the same except the choke doesn't have the bell crank tab. I guess that I'll just cut it off and use it.
Much obliged
Al
Todd78d Bugeye choke linkage Spridgets 5
Todd78d Choke Linkage Photo Austin Healey 0
M Choke Linkage Austin Healey 3
B Front carb choke linkage pin Triumph 5
K TR2/3/3A TR3 SU choke linkage horizontal bar that connects Triumph 2
M WTB: Tri Carb Choke Linkage Parts Austin Healey 8
M Choke linkage nuts Triumph 9
J TR2/3/3A tr3 choke linkage issues Triumph 7
doughairfield Pic of the choke linkage Triumph 0
S HS2 SU dual carb throttle/choke linkage Spridgets 10
DenverMGB Weber Carb 32/36 DGV - Choke Linkage? MG 18
NutmegCT TR2/3/3A TR3 choke linkage Triumph 12
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
D BT7 Choke Assembly Austin Healey 18
P MGB Zenith water choke gasket needed MG 4
D Choke Cable Length Austin Healey 0
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
L MGB 1977 MGB will only run on full choke MG 53
SherpaPilot TR6 Choke Assembly Triumph 0
D Carb Choke Cable Austin Healey 9
M TR6 1973 TR6 - broken choke cable Triumph 6
TomMull TR2/3/3A Which choke cable Triumph 12
sparkydave Zenith auto choke coming loose Spridgets 2
T TR6 TR6 Choke Cable Lubrication Triumph 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
K TR2/3/3A Couple of choke questions Triumph 1
K Choke cable replacement Austin Healey 1
D AH 300O MK1 Choke Knob Position Austin Healey 5
R Jensen-Healey Choke? Other British Cars 1
F TR2/3/3A Choke Cable Problem Triumph 29
F Choke sticking Austin Healey 22
N Enrichener [choke] wire Austin Healey 1
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
F TR2/3/3A Choke Triumph 1
edkap2002 TR6 72 tr6 choke cable Triumph 4
Patrick67BJ8 BJ8 Choke Cables Austin Healey 5
TRMark TR4/4A Choke Cable Routing Triumph 3
S TR2/3/3A choke operation from the factory !!!! Triumph 29
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
S TR4/4A aftermarket choke cable Triumph 3
sparkydave Zenith auto choke coming loose Spridgets 3
K TR4/4A Strombergs...wont idle unless choke pulled out? Triumph 7
UmmYeahOk GT6 I Give Up! Help A Millennial Out [Carb/Choke Related] Triumph 28
M TR2/3/3A Choke Cable Detent Device Triumph 11
Rob Glasgow Choke cable turnion Austin Healey 8
