HS2 SU dual carb throttle/choke linkage
Sportsdoc
Anyone have a picture of the proper way to attach the throttle and choke linkages with the three springs?
I'm putting mine back together and struggling with linking the throttles and chokes.
Thanks.
ChrisS
See
<a href="https://www.britishcarforum.com/bcforum/ubbthreads.php/ubb/showflat/Number/152577/site_id/1#import" target="_blank">this post,
</a> <a href="https://www.britishcarforum.com/bcforum/ubbthreads.php/ubb/showflat/Main/22346/Number/201039#Post201039" target="_blank">this post,
</a> and
jlaird
LOL, those are nasty carbs Chris. Please tell me that's the before shot.
ChrisS
That is the "during stripping the car for parts" shot.
S
Sportsdoc
Thanks, Chris. You're obviously smarter than I am for taking a pic before tearing it down!
HAN8L1965
I find this picture interestng, my 65 only had 2 springs both connected to the rear positions and none to the fuel linkage. The catalogs only mentions 2 which I have hooked up in the same manner in my rebuild. What function does the middle spring serve? I have plenty of tension with two.
Mark
S
Sportsdoc
I was wondering the same thing last night when I was putting the carbs and heatshield/manifold together. Mine had three springs, but two new ones have plenty of tension. Maybe a safety factor?
jlaird
The center spring is to provide tension on the gas pedal, overcome possible resistance.
Platinum
Or possible cable failure. /bcforum/images/%%GRAEMLIN_URL%%/smirk.gif
bugimike
Or even pedal return!! /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
C How to check for leaks at throttle shafts? [dual HS2's] Triumph 14
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
jehuie HS2 carburetor question… now with video! British Motor Corp 20
jehuie Will this lid work with my HS2 carburetor float chamber? British Motor Corp 4
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
Rut HS2 questions Spridgets 9
R SU HS2 rebuilds Spridgets 3
SD Bugeye HS2 interconnecting SS Braided fuel hose Spridgets 7
TomMull Post-War Other SU HS2 caburetor question Triumph 9
sim HS2 Rebuild ? Spridgets 8
AN5Sprite What Needle In Your HS2? Spridgets 3
D K&N RU-4410 on SU HS2's Spridgets 37
J Getting HS2 carb jet out Spridgets 11
T HS2 needles Spridgets 1
histerical Looking for some HS2 parts Spridgets 5
TulsaFred Float bowl to jet connection leak on HS2 Spridgets 8
RichBall HS2 and HS4 measurment Spridgets 7
Gundy HS2 customs Spridgets 8
BugeyeNJ58 Carb leaking HS2 at bottom of float chamber Spridgets 21
TexasSprite Rebushing HS2 Carb throttle shafts Spridgets 7
RickB Air cleaners for HS2 carbs? Spridgets 33
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
John Moore HS2 Stub Stacks Spridgets 0
T HS2 for 1275, right? Spridgets 7
jvandyke HS2 float level Spridgets 10
pakiwi HS2 - Carb Issue Spridgets 3
mccalebr Eye candy - Hap's HS2 carbs Spridgets 20
Hap Waldrop HS2 velocity stacks Spridgets 37
TexasSprite HS2 Carbs Spridgets 8
58Custom SU HS2 Piston assy movement-- question Spridgets 20
Luke_Healey HS2 question Spridgets 20
Atrus Carb velocity stacks - are these HS2 or HS4? Spridgets 2
Luke_Healey SU HS2 needle variation question Spridgets 11
ChrisS HS2's flooding in turns Racing 5
ChrisS HS2's flooding in turns Spridgets 14
middleagecrazy HS2 floats Spridgets 9
drooartz HS2 on a 948 Spridgets 3
Atrus HS2 jet needles Spridgets 4
HAN8L1965 Float Removal-SU HS2 Spridgets 5
Atrus [2] HS2 vs [1] HS4 Spridgets 10
M Need to replace fast idle screws for '74 midg. HS2 Spridgets 1
Woodie HS2's and apologies Spridgets 16
Woodie hs2's slight hesitation under load Spridgets 40
Woodie hs2 & vac to dizzy - urgent - car apart in drivewy Spridgets 11
SilentUnicorn hs2 problem Spridgets 7
A T-Series Switch HS2's for HS4's ??? MG 3
C HS2's...big ole' flat spot! Maybe I need to just pay someone. Triumph 27
D HS2's on a 1500...good, bad or ugly????? MG 17
nathandarby67 WANTED: S.U. HS2 Dashpots [Midget 1275] MG 3
