middleagecrazy
Has anyone had any luck with the brass floats that Moss Motors sells for the SU HS2 carbs. I have been having float problems in both cars with HS2 carbs. I was crusing the Moss catalog and noticed that they have a brass float that is a different design than the plastic ones. They also carry the Grose needle valves. The Sprite has the Grose needle valves in it but with no adjustments for the floats I have continueing issues with one or the other carbs flooding I had aluminum tabs that were added to the hinge point of the floats that allow for some adjustment.They improved the problem but they are weak and the adjustments only last a few days then its back to one or the other flooding again. I am considering replacing the floats and needle valves and think the design of the brass float with the adjustment tab and grose needles might be the solution.
Anthony
Anthony
