BugeyeNJ58
1275 engine in 59 BE. HS2 carbs. Driving car and noticed smoke coming into car. Stopped and saw that the rear carb (nearest firewall) was dripping gas onto exhaust pipe.
Checked it out and saw that gas is dripping at the bottom of the float chamber where the screw tightens into the float chamber. This is the screw that attaches the flow pipe from the float chamber that continues into the jet in the carb itself.
I made sure it was tight, but when I tap the hose where it attaches, small amount of gas leaks. Looked at an extra set of carbs I have and when I unscrewed that nut totally, say that there is a very small rubber grommer that sits in the screw tunnel that the flow pipe goes into.
Do you think this is what could be leaking? Can this part be purchsed? I'd rather buy one new than use another 20 year old part. Any other ideas?
Thanks...
Thanks...
