Jet Assembly sticking
doughairfield
I'm having a bit of a problem with one of my SU H6 carburetors on my TR4.
When i pull the choke out, it articulates the jet lever arm, pulling the jet assembly down, enriching the mixture I assume. Everything starts up fine. But when the engine warms up and I push the choke back in, the jet assembly doesn't move back up into the carb for normal running. I then have to pop the hood and push the jet assembly back up, resulting in smooth running.
I had the carbs rebuilt recently, but they were in pretty bad prior shape so I don't really know what the proper operation of the jet assembly is supposed to be.
NutmegCT
Doug - just my two cents:
I had the same problem with the H6s on my 1959 TR3.
Removed the jets, polished them with steel wool and toothpaste (!). And found that one of them was actually slightly bent, so it would "stick" in the jet assembly. Got two new jets.
Also made sure the cork gaskets were lubed inside the jet assembly. You may have rubber o-rings, but I'm pretty sure they need some lubrication so the jets will move through them.
Hope this helps.
Tom
Moseso
In my case (same problem) a mere application of a little silicone grease to the jet solved it. Polishing the jets surely won't hurt -- and then a little silicone grease too...
TR3driver
Great Pumpkin - R.I.P
:iagree:
I would also replace both the return springs, and the springs that hold pressure on the jet seals. These springs are not included in rebuild kits and hence not always replaced during rebuilds, but should be, IMO. It's quite common for folks to stretch the jet seal spring out to put more pressure on the seals (in an attempt to stop them from leaking), which can also cause the jets to bind. And the return springs just get weak with age soemtimes (even if someone hasn't modified them as well).
Original jets came in a high state of polish, but modern replacements don't. They need to be polished before installation. I also coated mine with a very thin layer of silicone grease.
doughairfield
doughairfield
Great advice, thanks. I've already replaced the return spring and put some lithium grease on the jet, although, just on the lower end near the coupler in my attempt to solve this problem.
Guess I'll pull it apart and give a good going over and check that jet to make sure it's true.
TR3driver
Lithium grease won't help much, as it will get washed away by the fuel. The pure silicone stuff should offer some lubrication longer.
JohnnyMead
Doug,
Have you disconnected the linkages and tried moving each jet/spring assembly by hand? You may be able to isolate the roughness or binding to a specific part of the system (one carb, part of the link, etc.).
John
M TR2/3/3A H6 Jet assembly leaks after rebuild Triumph 6
NutmegCT H6 carb jet bearing assembly Triumph 33
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
torque-drive MGB SU HS4 jet height adjustments MG 6
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
F TR4/4A SU HS6 jet initial adjustment jet not flush with bridge Triumph 7
Csarneson BN4 Windscreen Washer Jet Austin Healey 3
2 For Sale Jet for SU H6 Carburetor Other British Classifieds 0
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
Carlos TR4/4A GROSE-JET or Viton-tip for SU HS6 carbs? Triumph 15
K TR2/3/3A Unmarked SU jet needles? Triumph 3
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
S TR2/3/3A polish the jet Triumph 1
steveg HD series Jet Centering - a Caution Austin Healey 19
F TR2/3/3A Centering The Jet Triumph 14
T TR2/3/3A H6 jet bearing seals Triumph 3
H BJ8 jet drop measurement Austin Healey 8
BillyB62 TR2/3/3A Carb Jet Triumph 8
M SU Jet Centering Tool - A Worthwhile Investment? Spridgets 2
M TR2/3/3A Forward Carb Jet Lever Bent Triumph 12
TomMull TR2/3/3A Wrong SU jet? Triumph 0
N Jet Hot??? Spridgets 13
toysrrus TR2/3/3A HS6 Jet Assy Linkage Request Triumph 4
HealeyDave HD Carb Jet Adjusting Screw Question Austin Healey 2
sim HUS 2 main jet adjustment Spridgets 40
TRclassic3 TR2/3/3A SU Upper jet bearing position Triumph 5
K TR2/3/3A SU carb...after jet centered...jet lever hesitation. Triumph 3
T T-Series Need new jet levers MG 3
D Jet seals Triumph 2
K SU's again...Jet centering? Triumph 7
J Getting HS2 carb jet out Spridgets 11
TulsaFred Float bowl to jet connection leak on HS2 Spridgets 8
britndablood HD6 jet diaphragm only lasted 8 months Austin Healey 7
Bremer Jet needle removal Triumph 7
jdubois What the heck is this jet needle? Triumph 8
K TR2/3/3A TR3 SU H6 Jet[Gland Packing] Rubber O RING Size? Triumph 3
K TR2/3/3A TR3A SU Jet marking .100 ? Triumph 6
G Who sells jet-to-bowl line? Spridgets 6
Nelson SU jet centering Spridgets 11
G Fuel hose replacement from bowl to jet Spridgets 4
R Jet Hot Coatings TVR 6
drooartz Jet-Hot headers came today! Spridgets 5
drooartz Jet Hot header coating questions Spridgets 13
H HS6 JET identification Triumph 2
G I called Jet Hot about my peeling SS headers... Triumph 20
G Jet Hot coating peeling off my headers........... Triumph 9
B SU Jet ID's Spridgets 5
JPSmit carb jet question Spridgets 3
NutmegCT Binding choke and piston - it was the front jet! Triumph 2
