TR2/3/3A Unmarked SU jet needles?
karls59tr
Bronze
Building carbs on the work bench. Is there any way I can tell if a jet needle is lean or rich? Bought them some time ago and they came unmarked. Do the needles all come unmarked now? Did they not used to come with markings at the top?
titanic
Look on the side of the shank. You may have to use a magnifying glass as the marking are sometimes very faint.
Berry
2liter4cyl
Bronze
I recently bought a genuine SU rebuild kit from MM. The mark was so poorly done, to avoid bending the needle, I had to file off the burr around the ID. For it's sure I knew the size! LeT
TR3driver
Great Pumpkin - R.I.P
If they really aren't marked, then the only way I know is to measure at each station, and compare the measurements to a chart or a known needle.
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
torque-drive MGB SU HS4 jet height adjustments MG 6
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
F TR4/4A SU HS6 jet initial adjustment jet not flush with bridge Triumph 7
Csarneson BN4 Windscreen Washer Jet Austin Healey 3
2 For Sale Jet for SU H6 Carburetor Other British Classifieds 0
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
Carlos TR4/4A GROSE-JET or Viton-tip for SU HS6 carbs? Triumph 15
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
S TR2/3/3A polish the jet Triumph 1
steveg HD series Jet Centering - a Caution Austin Healey 19
F TR2/3/3A Centering The Jet Triumph 14
T TR2/3/3A H6 jet bearing seals Triumph 3
H BJ8 jet drop measurement Austin Healey 8
BillyB62 TR2/3/3A Carb Jet Triumph 8
M TR2/3/3A H6 Jet assembly leaks after rebuild Triumph 6
M SU Jet Centering Tool - A Worthwhile Investment? Spridgets 2
M TR2/3/3A Forward Carb Jet Lever Bent Triumph 12
TomMull TR2/3/3A Wrong SU jet? Triumph 0
N Jet Hot??? Spridgets 13
toysrrus TR2/3/3A HS6 Jet Assy Linkage Request Triumph 4
HealeyDave HD Carb Jet Adjusting Screw Question Austin Healey 2
sim HUS 2 main jet adjustment Spridgets 40
TRclassic3 TR2/3/3A SU Upper jet bearing position Triumph 5
K TR2/3/3A SU carb...after jet centered...jet lever hesitation. Triumph 3
T T-Series Need new jet levers MG 3
D Jet seals Triumph 2
K SU's again...Jet centering? Triumph 7
J Getting HS2 carb jet out Spridgets 11
TulsaFred Float bowl to jet connection leak on HS2 Spridgets 8
britndablood HD6 jet diaphragm only lasted 8 months Austin Healey 7
Bremer Jet needle removal Triumph 7
jdubois What the heck is this jet needle? Triumph 8
K TR2/3/3A TR3 SU H6 Jet[Gland Packing] Rubber O RING Size? Triumph 3
K TR2/3/3A TR3A SU Jet marking .100 ? Triumph 6
G Who sells jet-to-bowl line? Spridgets 6
Nelson SU jet centering Spridgets 11
G Fuel hose replacement from bowl to jet Spridgets 4
doughairfield Jet Assembly sticking Triumph 6
R Jet Hot Coatings TVR 6
drooartz Jet-Hot headers came today! Spridgets 5
drooartz Jet Hot header coating questions Spridgets 13
H HS6 JET identification Triumph 2
G I called Jet Hot about my peeling SS headers... Triumph 20
G Jet Hot coating peeling off my headers........... Triumph 9
B SU Jet ID's Spridgets 5
JPSmit carb jet question Spridgets 3
NutmegCT Binding choke and piston - it was the front jet! Triumph 2
VelodromeRacer Jet Coat discount Austin Healey 2
