SU jet centering
Nelson
I am having a bear of a time getting my jets centered. With the locking nut very loose I can get the piston to fall freely and land with a soft thud. As I slowly tighten the nut I keep dropping the piston after every very slight tightening and I get the thud until the nut begins to get tight at which time the piston no longer falls freely. If I use the lifting pin the piston lifts but will not fall without a slight push. The carbs are on the car and I would prefer to do the adjusting there but if all else fails I guess I'll have take them off and try it that way. I have watched John Swift's video and the adjustment looks so easy when he does it. Is there a trick to getting them locked in the proper position???
Platinum
Without the "anvil" centering tool, patience is the only thing.
Nelson
Nelson
Could you clue me in on what the anvil tool is? I have a lathe and wonder if I could make one.
Platinum
Absolutely!
Imagine a teeny-tiny hockey puck with two short pins in the center. One pin is the shank diameter of the needle shoulder (that is inserted into the piston), the other is the diameter of the jet orifice (less a thou or two for fit). replace the needle in the piston with the anvil, jet all the way at the top of the tube, make sure the anvil is in the jet orifice and tighten the locking nut.
The ones I have are aluminum, but about anything will work. Good luck and report back! :savewave:
64rocksprite
Doc - you wouldn't have a pic of this beast would you? Where did you get it? I bought a jet centering tool..(looks like a punch) it doesn't seem to fit HS2's
Thnks
jlaird
Hmmm, take tops of of carbs the part we shine with the piston in it.
Leave piston in the seat, Kind of wiggle is about as you tighten the seat.
Good job, all done. seat centered. replace top with piston in it. test.
Nelson
Nelson
I tried that but when I replaced the domes and tightened the screws the piston hung up. I'm going to make my own version of the Moss tool. It will fit snugly through the dome and then I'll have it centered with the dome in place. It is a good use for my lathe.
Sarastro
I think what happens is that, after being tightened a few times, the parts take a set. Then, you can get everything centered perfectly when the jet is loose, but when you tighten it, bumps fall into grooves and everything shifts. To get around this, loosen the jet assembly, move things around, and then slowly--really slowly--tighten it as you lift the piston and drop it. If the needle starts to bind, loosen the nut and move things around again. Eventually, with a little luck, you'll get things so you can tighten it without the jet moving. It's a real pain, but it can be done.
If you want to try the anvil, at least one is included in the set of SU tuning tools that comes in a blue wallet--I don't know who makes them. You can see one here. There might be a couple of different sizes, though, so you might have to get a specific one.
spritenut
Rotate the jet inside the nut, most times centering the jet by just loosening the nut lets it go right back in the same spot time after time.
Turn it by hand 90* or so and try it again.
Patience for sure but then again, I have a jet centering tool :wink:
But I used to do it the hard way.
Nelson
Nelson
Rotating sounds like a good idea. Tomorrow I'll machine my own tool and give the rotation a try along with the tool.
The tool comes with the SU carb tool, really the only reason to buy one fo these and it does not come separately, I got my toll kit form Gordon at the B Hive. It just as Doc stated, so if you have a lathe, then sure you could make yourself one. There are also two different styles of jet bearings, the ealrier one leave a fairly good gap arounf the jet bearing bore hole in the carb body, the later one fit the bore fairly snugly. The earlier ones can be a bear to center, what happen over time the flat area that snugs up against the carb body can get a burr on or be slightly salnted over time, Joe Curto recommended fix for this is the face that area on a lathe so it is flat and tru again, I've done that and it work, but what I do mostly since tons of scrap SU padrt lying around is get a later jet bearing and stick that in there.
Here's another thing I do, mechanics are always trying to fiquire out ways to save time, do the job just as good, and beat the clock as well, so when I rebuilding a set of carb, I leave the jet bearing and retianing nut in place when I clean and media clean a set of carb bodies, then I have a small flex hone the proper size to hine the ID of the jet bearing, it's a huge time saver when rebuilding SU carbs.
jlaird
Again, I am impressed Hap. Would not have thought of that. Think my rear carb needs that trick.
steveg HD series Jet Centering - a Caution Austin Healey 19
F TR2/3/3A Centering The Jet Triumph 14
M SU Jet Centering Tool - A Worthwhile Investment? Spridgets 2
K SU's again...Jet centering? Triumph 7
D Jet centering tool Triumph 3
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
torque-drive MGB SU HS4 jet height adjustments MG 6
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
F TR4/4A SU HS6 jet initial adjustment jet not flush with bridge Triumph 7
Csarneson BN4 Windscreen Washer Jet Austin Healey 3
2 For Sale Jet for SU H6 Carburetor Other British Classifieds 0
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
Carlos TR4/4A GROSE-JET or Viton-tip for SU HS6 carbs? Triumph 15
K TR2/3/3A Unmarked SU jet needles? Triumph 3
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
S TR2/3/3A polish the jet Triumph 1
T TR2/3/3A H6 jet bearing seals Triumph 3
H BJ8 jet drop measurement Austin Healey 8
BillyB62 TR2/3/3A Carb Jet Triumph 8
M TR2/3/3A H6 Jet assembly leaks after rebuild Triumph 6
M TR2/3/3A Forward Carb Jet Lever Bent Triumph 12
TomMull TR2/3/3A Wrong SU jet? Triumph 0
N Jet Hot??? Spridgets 13
toysrrus TR2/3/3A HS6 Jet Assy Linkage Request Triumph 4
HealeyDave HD Carb Jet Adjusting Screw Question Austin Healey 2
sim HUS 2 main jet adjustment Spridgets 40
TRclassic3 TR2/3/3A SU Upper jet bearing position Triumph 5
K TR2/3/3A SU carb...after jet centered...jet lever hesitation. Triumph 3
T T-Series Need new jet levers MG 3
D Jet seals Triumph 2
J Getting HS2 carb jet out Spridgets 11
TulsaFred Float bowl to jet connection leak on HS2 Spridgets 8
britndablood HD6 jet diaphragm only lasted 8 months Austin Healey 7
Bremer Jet needle removal Triumph 7
jdubois What the heck is this jet needle? Triumph 8
K TR2/3/3A TR3 SU H6 Jet[Gland Packing] Rubber O RING Size? Triumph 3
K TR2/3/3A TR3A SU Jet marking .100 ? Triumph 6
G Who sells jet-to-bowl line? Spridgets 6
G Fuel hose replacement from bowl to jet Spridgets 4
doughairfield Jet Assembly sticking Triumph 6
R Jet Hot Coatings TVR 6
drooartz Jet-Hot headers came today! Spridgets 5
drooartz Jet Hot header coating questions Spridgets 13
H HS6 JET identification Triumph 2
G I called Jet Hot about my peeling SS headers... Triumph 20
G Jet Hot coating peeling off my headers........... Triumph 9
B SU Jet ID's Spridgets 5
JPSmit carb jet question Spridgets 3
NutmegCT Binding choke and piston - it was the front jet! Triumph 2
