1275 timing/ carb pistion sticking
RonR
While trying to help a friend time the 1275 engine in his recently acquired Bugeye, we could not see or feel any indication on the pulley indicating the TDC notch. We looked and felt around the entire circumference of the pulley.
Does anyone have any suggestions what may have happened and how to correct these things?
Also, one of the HS2 carbs’ piston needle binds up after centering the jet and tightening the nut. Loosening the nut allows the piston to fall with the “clunk” sound. However, even with the nut lose the needle seems to be sticking as upon acceleration of the engine, this piston does not raise nearly as quickly as the other carb piston. I assume that needle is bent and we should replace both the needles and jets in each carb.
Thanks.
Ron
GeeBee1
If it has a dampner pulley, then you should have a little slot on the bottom @ TDC. Also, you can take out the spark plugs and valve cover to get a reasonable idea as to where you are hoping to find it.
Pat
jvandyke
You can try switching the carb pistons around for better matching. Can even try lightly polishing the sticky one. That is assuming the needle is straight.
dklawson
Visit YouTube and search for John Twist's (University Motors) videos on matching SU carb pistons. He'll quickly walk you through how to match the carb pistons.
You may wish to drop the jet completely out so you can remove the guide tube, crush washers, and bearing nut. A washer "may" have developed a distorted top surface that's kicking the jet off to the side when you make that last little bit of tightening of the bearing nut. You can dress the washer flat on some wet/dry paper on a flat surface and try using it again.
Remember that you will be lowering the jet by 2 turns of the adjusting nut to achieve the initial "start" setting before setting the mixture properly. What I'm about to suggest may not sound "correct" to purists, but if the needle binds a tiny bit but moves freely when the adjusting nut is backed out 1 turn, you're probably still "OK" with that degree of centering.
For the timing issue, you may want to visit Jeff's web site: https://www.advanceddistributors.com (look under the Products tab)
He sells a pointer and calibrated pulley tape/decal that will move the timing marks "up top" so you can see them easier.
M 1275 Timing Cover Vent Spridgets 2
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
C Wanted Timing gear cover 1275 Spridgets Classified 2
jaegzie I have no timing marks anywhere on my 1275. Spridgets 14
TulsaFred Timing Gear positioning on 1275 Spridgets 7
lbc_newbie 1275 Midget, Sprite Timing Tape Kit Spridgets 2
Jer Stroboscopic Timing - 1275 cc Spridgets 10
T Double row timing chains - worth doing on a 1275? Spridgets 17
nathandarby67 1275 Timing advice Spridgets 12
SilentUnicorn 1275 timing chain question Spridgets 2
CARSINC WANTED: 1275 Engine Spridgets 0
drooartz 1275 cruising RPM Spridgets 5
D A distributer question on the 1275 engine. Spridgets 7
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
A Bugeye engine swap, 948 to 1275 Austin Healey 11
M Judson Supercharger On A 1275 Spridgets 6
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Jim_Gruber 1275 Crankcase capacity is? Spridgets 4
N 1275 cams? Spridgets 2
T matching 1275 to bugeye rad ?? Spridgets 12
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
6 1275 Head to block dowel pins Spridgets 10
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
M Wanted 1960 Bug eye sprite 1275 ! Austin Healey Classifieds 0
