Dampner for a 1275 [damper? dampener?]: recommendations
twas_brillig
I'm hoping to rebuild a 1275 this winter for our BE and would appreciate thoughts regards a proper dampner (dampener; damper). We just pulled its 948 and it has just a steel pulley on the front; I believe that the 1275 can benefit/requires a proper dampner, but there appear to be a few available with a great variety of prices and would appreciate some guidance. Thanks, Doug
Bob Claffie
This is a totally uneducated guess, (worth 2 cents). Since balancers are individually balanced any one would have no effect on the overall engine balance. However, if you chose a "high performance" cam you MIGHT benefit from a bigger balancer to counter the inherent roughness of the hot cam. On the other hand if using a stock cam I would go for the smallest. lightest balanced available to possibly aid in acceleration.
Pythias
You need a dampner on the crank pulley for a 1275. They did not come or are then needed on the 948s or 1098s. I'm not sure where to get one other than the usual suspects. Used ones are generally worn out.
T
twas_brillig
We put a new dampner on our BJ7 a few years ago, but lucked out in that BPNW had a sale on. Doug
PS: yeah, and the old stock one was definitely junk, due to time.
Roger
Bronze
Damper or dampener, not dampner! Try spell-check.
The long stroke of the 1275 coupled with the relatively heavy piston causes vibration that should be damped.
T
twas_brillig
Hmm: Bill Gates has learned to spell! I just tried out tyre, damper, dampner, dampener, neighbour and favourite in Word, and Bill was happy with all the spellings. However, Google appears to still be challenged regards 'proper' spelling of the Queen's English... Doug
glemon
The 1098 is actually a longer stroke engine than the 1275, probably partly why the 1275s love to rev so much.
Mini Mania has the best selection of upgraded parts for A series engines, including dampeners.
JFS TR2/3/3A BF&G Dampner Seal Triumph 8
K Dampner Replacement In or Out? Austin Healey 49
jlaird Question-Front dampner puller Spridgets 2
L Getting the Vibration Dampner Off Austin Healey 12
L Crankshaft Vibration Dampner Austin Healey 4
CARSINC WANTED: 1275 Engine Spridgets 0
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
D A distributer question on the 1275 engine. Spridgets 7
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
A Bugeye engine swap, 948 to 1275 Austin Healey 11
M Judson Supercharger On A 1275 Spridgets 6
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Jim_Gruber 1275 Crankcase capacity is? Spridgets 4
N 1275 cams? Spridgets 2
T matching 1275 to bugeye rad ?? Spridgets 12
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
6 1275 Head to block dowel pins Spridgets 10
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
M Wanted 1960 Bug eye sprite 1275 ! Austin Healey Classifieds 0
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
Jim_Gruber 1275 Damper Pulley Needed Spridgets 16
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
Gerard 1275 piston ID Spridgets 2
