1275 Blueprints
S
Stan Kowznofski
Thanks Blue Max but I already have that manual. What I am looking for are the actual specification drawings that show all the dimensions, hole & thread specs, cylinder center to center dimnsions, etc.
BlueMax
If your engine is intact you want need engineered drawings. Just measure what you have. I trash all my bolts anyway and go back with grade 8 or ARP for the high stress components. Why do you need cylinder center to center dimnsions?
S
Stan Kowznofski
That was just an example, but C to C dimensions would allow me to adjust the cylinder bores at re-boring time to put them where they should be providing cylinder wall thickness will allow it. Also for things like camshaft to crankshaft alignment, relationships between parallel but non co-planer surfaces, etc. I'm looking for all the details as they were originally intended for design purposes for other accessories and options. I'm a bid of a mad tinkerer!
JPSmit
That's a whole new level of crazy! well done sir. I am not aware that what you seek exists though. (at least not easily) perhaps an engine builder? or one of the bigger clubs.
Hap Waldrop is just getting re-acquainted with the forum - her builds race engines - https://www.acmespeedshop.com/ - he might know.
S
Stan Kowznofski
I once built a Briggs & Stratton racing go kart engine where I offset and angle bored the cylinder to improve the connecting rod angle then angle milled the engine deck to 90 degrees to the cylinder to help unshroud the valves (remember, it's a flathead) and disguise the angle bore and then machined the engine bottom parallel to the deck so the tech inspectors wouldn't notice. The only way to find it would be to measure the cylinder centerline to the crankshaft centerline & they didn't have the tooling sophisticated enough to determine the offset. Made incredile horsepower, relatively speaking of course!
BlueMax
A and B type BMC engines have inconsistency with core slippage. You would be better off in machining adapters after you ultrasound the block and use the main bearing centerline. You can then probe all your centers with a C & C probe to determine what you have to work with.
https://www.youtube.com/watch?v=7avTX3BNmuA
There's several 1275 blocks to choose from one is the most coveted , if you don't have this book you'll find a HUGE amount of useful information. Tuning The A Series Engine by David Vizard third edition.
CARSINC WANTED: 1275 Engine Spridgets 0
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
D A distributer question on the 1275 engine. Spridgets 7
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
A Bugeye engine swap, 948 to 1275 Austin Healey 11
M Judson Supercharger On A 1275 Spridgets 6
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Jim_Gruber 1275 Crankcase capacity is? Spridgets 4
N 1275 cams? Spridgets 2
T matching 1275 to bugeye rad ?? Spridgets 12
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
6 1275 Head to block dowel pins Spridgets 10
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
M Wanted 1960 Bug eye sprite 1275 ! Austin Healey Classifieds 0
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
Jim_Gruber 1275 Damper Pulley Needed Spridgets 16
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
Gerard 1275 piston ID Spridgets 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
Rut How much does a 1275 weigh? Spridgets 8
A For Sale Sprite/Midget 1275 clutch cover. Austin Healey Classifieds 0
Rut 1275 rear seal help Spridgets 0
