How much does a 1275 weigh?
Rut
I already know the answer and I’m probably the only person who would do this, but when an engine falls off the cart don’t try to catch it! Cleaning up the garage for the holidays and to give my wife her parking spot back, I decided to rest the completed 1275 on a furniture dolly as I normally do and roll it into the corner. As I was rolling along pushing the cart the engine fell off and toward me and in my infinite wisdom I decided to catch it. Physics must not be my strong suit because picking up a 1275 is very different from catching a falling one. Other than a few scrapes and bruises I’m ok and the engine is as well...next time I’ll strap it down.
Rut
nomad
Glad to hear your OK. Serious back problems have resulted from less. I've seen big strong guys swapping engines in Spridgets, at the track, by manhandling them but never considered my back up to it.
Kurt.
bugedd
Gotta be 200lbs or more. I dead lifted mine onto an 18" box, it took everything I had.
twas_brillig
My recollection from the shop manual is that a 948 complete engines weighs 225 pounds. But I'll check later. And since the blocks are pretty much the same, does that mean that the 1275 weighs less 'cause it's got more air in it?
AngliaGT
It seemed like 500 lbs. when I unloaded mine down from the F150.
Luckily,it was on rollers.
Rut
Rut
Stationary it weighs 267 lbs, falling it weighs about 2670 lbs! Don’t try to catch it!
Rut
AngliaGT
Rut
......and it will go 200mph when falling.....
twas_brillig
The Austin Healey Sprite Mark l Workshop Manual says 245 pounds under 'Engine', but there's no indication of whether or not that includes carbs, generator and exhaust manifold. The only other weights that the manual lists are 35 pounds for the transmission and 83 pounds for the rear axle. Doug
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
drooartz How much does the engine move? Spridgets 10
V MGB Folding convertible vs stow away. What years? How much difference? MG 2
S BJ-8 SU Fuel Pump Clicks Much Faster Than Before Austin Healey 9
DrEntropy MGB Differential with too much lash MG 5
HealeyRick Why 100Ms Cost So Much Austin Healey 14
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
Healey Nut sooooooooo , how much will it go for ?? Austin Healey 24
AHS TR2/3/3A Residual brake pressure valve - how much front wheel drag? Triumph 18
GTP1960 TR2/3/3A How much is to much fretting? Triumph 10
NutmegCT So many cars! So much has changed! Other Cars 10
D TR4/4A How much play acceptable for input shaft bushing? Triumph 2
HealeyRick How Much is that Healey in the Window? Austin Healey 7
TomMull Air Compressors, how much is too much? Restoration & Tools 7
glemon How much paint? Restoration & Tools 8
Trevor Jessie Waaaay too much body roll Spridgets 14
T TR2/3/3A Is 5.5 lbs too much fuel pressure? Triumph 9
Martinld123 Why too much valve clearance after adjustment? Austin Healey 2
K TR2/3/3A How much oil should the steering box have in it? Triumph 6
DornTRoriginal General Tech The Devil is in the Details! Am I asking too much? Triumph 21
Lukens TR2/3/3A How much travel at the clutch slave? Triumph 12
S How much grease for the drive [prop] shaft plunger Austin Healey 3
J How much movement in slave cylinder plunger . Austin Healey 2
T TR2/3/3A How much vibration in a Triumph 4 cylinder engine? Triumph 12
J Clutch fork free play on BJ8 How Much? Austin Healey 13
F Too much procrastination[maybe long winded] Austin Healey 9
H TR4/4A Triumph 250-K by Pete Brock--anybody recall how much Brock advertised it for? Triumph 1
E How much should i pay for a complete 100/4 engine ? Austin Healey 4
richie TR4/4A How much oil is normal.. Triumph 6
drooartz How much fender beading for Bugeye? Spridgets 17
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
M Cleaning up under the hood - just how much needs to be painted? Spridgets 2
Jim_Gruber How much spare fabric in needed to cover panels / dash on a BE. Spridgets 10
J New engines burning oil, Too much fuel? Triumph 14
B How Much Pedal? Spridgets 2
J How much to buy an engine block and head? MG 3
johnrip how much gas for winter storage Triumph 17
V TR2/3/3A TR3A Brake Pedal - Too Much Travel Triumph 6
AN5Sprite T-Series Considering an MGTF, how much $$$ MG 20
nevets How much brake fluid to fill the system? Austin Healey 3
W 2012 Daytona 200 - missed it by that much British Motorbikes 6
rkep01 How much do you think this will sell for? Spridgets 33
F T-Series How much to pay? Photos of 1955 MG TF 1500 MG 17
F How much of a premium? BJ8 vs. BJ7? Austin Healey 16
CZ_Dave One is too much, a hundred isn't enough MG 4
R Getting Much Closer Triumph 73
Darrell_Walker Leaks, some fixed, some maybe not so much Triumph 7
F Am i Worrying to much??? Spridgets 9
V How much extra engine oil with oil cooler??? Spridgets 5
Got_All_4 TR2/3/3A TR3 leans too much to the right Triumph 10
